Question about Maytag Washing Machines
Our Maytag Bravos MCT washer suddenly has low water level. My wife switched Ed to hand wash mode for one load and after that it's low water level. Model# MVWX655DW1
    Top Expert:
  • Maytag Master
  • 52,796 Answers
A level sensor may have failed
Posted on Jan 14, 2019
SOURCE:
  • 4 Answers
SOURCE: How reset clean washer reminder on Bravos washer
This is just a factory setting that reminds you to clean the washer to avoid that musty smell. You can buy tablets called Affresh or other similar cleaners for washing machines. They sell these items at Target, Walmart, Lowes and Home Depot. You can also substitue 1 Cup of Bleach in the washer. Then once you add whatever solution you have decided to clean it with you simply select the wash cycle on the machine called "Clean Washer with Affresh" Once you have done this the light should go out. You can also reset this indicator light by pushing the button next to the light that says Reset clean washer reminder. Hope this helps!! :)
Posted on Aug 11, 2010
  • 29 Answers
SOURCE: I have a brand new
I had this one come up on a washer I had professionally installed for a client. When I looked into it I found there were shipping blocks made of squeaky Styrofoam the installers left in place. Only made the noise when it was full of water and working hard shifting back and forth in agitation. It said right in installation instructions to take the shipping blocks out too.
Posted on Feb 20, 2011
garycole11
  • 4 Answers
SOURCE: I have a Maytag bravos MCT topload washer and it won't drain and spin??
Pump is gone
Posted on Apr 06, 2018
  • 52796 Answers
SOURCE: Maytag Bravos MVWX655DW1 washer will not turn on. Have checked electrical connection and circuit breaker.
Could be a defective switch or defective control board
Posted on May 30, 2018
iam6fan
  • 6289 Answers
SOURCE: forgot to turn water on for MVWX655DW1 Maytag Bravos washer. Motor still keeps running, no sensor lights, can't reset or shut down.
Cut water on. Push cancel / pause button and wait about 15 minutes. It should reset.
Posted on Oct 21, 2018
My 2016 Maytag bravos XL MCT showing error code F5. Is this a simple fix?
Lid lock error. They are explained here:
https://www.searspartsdirect.com/washer-repair/error-codes/maytag-bravos-mvw-top-load-washer-error-codes.html
Oct 12, 2018 | Maytag Washing Machines
Maytag bravos mct washer keeps filling with water on drain and spin cycly
first thing to do is a reset. unplug it for 5 min and plug back in to see if it resets to factory settings.
Jan 21, 2018 | Maytag Washing Machines
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
Is there a reset on a may tag bravos mct washer
Top 565 Complaints and Reviews about Maytag Bravos
www.consumeraffairs.com > Shopping > Appliances
Rating: 1.2 - ‎241 votes This Maytag Bravos HE machine has the poorest design! ... So disappointed in Maytag - I have a 2013 Bravos washing machine that if I had it repaired again (less .... Called Maytag because my owner's manual stated I had a 10 yr warranty.
Jul 26, 2015 | Washing Machines
Noisy spin cycle and stuck on high
Spin solenoid could have water leaking onto it and it stuck on , but noise is most likely caused by bearing getting water into them,dose it leek water on the floor?
Jul 19, 2014 | Maytag Bravos MTW6600T Top Load Washer
Just got a new maytag bravos washer and it will not go past the sensing stage and as it puts water into the washer it drains as fast as it goes in
You must make sure the drain hose is above the water level and not in the water in the "P" trap of the house drain. There must be air to prevent siphoning. The drain hose should not go more than about 12" down in the drain tube.
May 28, 2011 | Maytag Bravos MTW6600T Top Load Washer
I have a brand new Maytag Bravos MCT top loaded washer. It makes a squeaky noise when agitator is cleaning. The squeak is getting louder and I've probably only used the washer a dozen times. We checked...
Feb 20, 2011 | Maytag Dependable Clean Top MAV5920EWW Top...
Maytag Bravos top load gives LF code..not working ... any idea?
Have same problem. Service tech said LF code is caused by low water pressure coming into machine. Tech verified water flow looked fine, getting new controller installed tomorrow.
Jul 18, 2009 | Maytag Bravos MTW6600T Top Load Washer
Washing Machines Logo
79 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
