Initially the ice maker works but after several batches the evaporator rods do not release the cubes and the machine shuts down.
SOURCE: no water for ice maker
make sure wire is in down position this is like the on and wire up is off
SOURCE: Ice maker won't make ice after replacing water filter -plugged
I've had the discolored water before when replacing the filter. It normally means that there was gunk in the water line.
Do you still hear the ice maker trying to draw water in?
If not, the water pump might be burnt out.
If so, see below.
The water lines that feed the dispencer and the ice maker split after a certain point.
It's possible that the line that feeds the ice maker might be clogged. You should be able to get to it by removing a few screws and pulling off the back panel of the fridge. Then you can check them out and remove the clog.
Comment on the post if more helps is needed.
SOURCE: Ice Maker will not release the frozen ice cubes from tray
The icemaker use an avaporator system with an heatinc coil and a fan to release cubes.
In your case either the heating coil or the fan in the icemaker must be replaced.
parts can be purchased from partselect.com.
SOURCE: Maytag ice maker will not release cubes
Sounds like it has a " seeping " water valve . Only thing to do is replace the water inlet valve . There is a certain amount of water to go into icemaker at fill . A seeping valve will let water continually drip into icemaker , making large cubes which icemaker cannot dump . A larger amount of seeping , will overfill the icemaker , and drip into the freezer and floor .
