Do you mean the KGSS907SS01? Kitchenaid ranges usually don't have three letters before the last two digits in the model number.
If so, all you need to do is press the Clock Set/Start keypad (below the 7) and then type in the current time. Then press the Clock Set/Start keypad again. The range uses a 12-hour clock.
I found the Owner's Manual at Sears Parts DIrect: https://www.searspartsdirect.com/partsdirect/user-manuals/kgss907sss01-kitchenaid-parts-manual . The instructions for setting the clock are on page 12. The direct link to the manual is currently https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0809512.pdf . Manuals Lib does list a KGSS907SSS model. The manual is available here: https://www.manualslib.com/products/Kitchenaid-Kgss907sss-30-Inch-Slide-In-Gas-Range-12919.html . The directions for setting the clock are the same.
I hope this helps.
SOURCE: KitchenAid Microwave Model KhhS179L
First I would be sure the outlet is okay. You could try plugging a lamp into that outlet and wiggling the plug to be sure it's okay.
Otherwise, it may be a bad internal connection causing a power loss, or it has a problem with the keypad or control board.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
SOURCE: BEEPING F-1 FLASHING
Evidently there was a faulty part that caused a problem and it resulted in the F1 code showing up. There was a class action lawsuit and settlement. Check out this website... It tells all about it and maybe you can figure out if this is what your problem is.
http://www.ovensettlement.com/faq.php3
SOURCE: How do I set the clock time on Stoves Cooker
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
SOURCE: kitchenaid superba gas stove not lighting unless
Sounds like glow plug for bottom bake...or control problem....They have had control problems before..
Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
