SOURCE: jet model jwbs-14cs bandsaw purchased used, need manual
http://www.cpojettools.com/products/708115k.html
Scroll down and click the "Manuals" tab. Your free PDF awaits...
SOURCE: hi i have a craftman bench 10 inch bandsaw that has blade drif
The problem could be one of two things. The tires could be worn or glazed with rosin. Try cleaning the tires with mineral spirits to remove the build-up. The other possibility is that the pulleys are out of alignment. To check this, put a straight edge across the face of the lower pulley and see if squares with the upper pulley, if it doesn't, loosen the set screw on the upper pulley and adjust accordingly
SOURCE: Sears 12" bandsaw Model 11324200 I
Here is a link to the parts diagrams. You can order new parts and have them shipped right to your home.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-113247210/0247/0744100?pathTaken=
