Coffee Makers & Espresso Machines Logo
D
Dorothy Flanagan Posted on Jan 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I Have a KitchenAid coffee machine model 5KES0503. There is more water running into the drip tray from the capsule area than out through the spout into the cup. Tried descaling no improvement
timoboon2
Level 2:
Sergeant:
  • Expert 360 Answers
  • Posted on Jan 14, 2019
timoboon2
Expert
Level 2:
Sergeant:
Answers
360
Questions
0
Helped
154699
Points
959
Probably the device has calcium built up in it. Do a proper flushing round of at least 500ML (around 15 flushings) or do the "Decalcify" program with the needed tablet for the machine.
  • Dorothy Flanagan
    Dorothy Flanagan Jan 14, 2019
    Thanks for that. I’ll give that a try
  • Amichai Hayun Oct 10, 2019
    i tried to do it but still leaking any other idea how to solve it? thanks
5 Related Answers
Pierre Laplante
  • 2061 Answers
  • Posted on Jan 24, 2008
SOURCE: Blocked coffee 'spout'
you have to remove the piece with hole in it you got 1 side that block if you dont whant to remove try with steel wire pass that in the hole it should unblock cheers
stefano-61
Stefano Andreani
  • 69 Answers
  • Posted on Jan 08, 2009
SOURCE: coffee not dripping out of the machine
let it run without coffe tablets, if no water comes out probably the conducts are obstructed, may be calcium in the pipes...do water come out somewere else?...
z34aga
Sulejman Sulejmani
  • 138 Answers
  • Posted on Mar 28, 2009
SOURCE: Water in the drip tray of coffee machine
take out the mecanism and clean it how is instructed in manual, than get it back carefuly. Pay attention on position of mecanizm.
Anonymous
  • 60 Answers
  • Posted on Mar 26, 2010
SOURCE: Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
paul_on_trav
  • 17 Answers
  • Posted on Aug 07, 2010
SOURCE: Hi, I have an XP7240 and recently i only half a
I can remove the bean container by pulling off the grind selector knob and removing the only screw.
Then remove the scute for the cleaning tablets. Then remove the two screws that were covered by the scute. Remove the water tank. Under the tank remove the two screws.
Then the trick where everyone seems to look for: The facade of aluminum can be moved off. Set the machine on the floor and pull hard upwards at the facade. This comes off (pull hard!) and four screw are uncovered. Remove them and pull then back housing of the machine (remove first the containers/drawers). Now the inner parts are freely accessible. Take photos and remove the components from top till bottom to get to the bad parts that need replacement. It's a lot of work but if you're handy you can get to the valve on the bottom of the machine. I have the same problem but haven't looked up the replacement part (can be expensive). Good luck!
1helpful
Delonghi Nespresso Coffee Machine Model EN66 After years of great use our machine now has small drips from the main coffee/water spout after use.
Try running apple cider vinegar through it. A few times. This is a mild acid that will get rid of mineral deposits from water. I do this on my coffee maker. Run straight water a few times after to get rid of the vinegar taste.
Notice deformation of the capsules ,water also leak to the tray
is it everytime little coffee,or sometimes?
If is everytime -you have to descale the machine,if just sometimes you have to cllean flowmeter,wich is on the back of machine.
Nespresso U, coffee does not come out the spout, goes down into the capsule bin.
Please read this
https://www.thedebuguy.com/blog/debugging-nespresso-machine
1helpful
4answers
Nespresso U coffee does not come through the spout
There are two nozzles in front of the machine attached together, the nose of the bigger one on the top slides into the smaller one on the bottom. When it makes coffee, the spout outside the machine becomes lower so coffee can come out. When it is done making coffee, the spout goes up so water/coffee drips in the drip tray. If one of the nozzles breaks, the spout on the smaller one will not go down and the inside end is lower and coffee goes inside the drip tray. It has nothing to do with cleaning.
We have a brilliant Briel Multipro that we use every day but when we have made a cup of coffee and release the coffee holder, steam and hot water spurts from the head area...It stops after a few seconds...
First, I'm NOT a Briel technician, But if you still have pressure from the removal of the portafilter (or capsule) then the exit or pour spout is clogged. You can soak a standard portafilter in warm water over nite and wash it clean in the morning. Really bad? then soak in urn cleaner and flush thoroughly prior to use. For capsule machines follow the MFR's instructions to properly flush the machine. You may also try to "fool" the machine into making a 'no coffee' shot by reusing old capsules over and over again to try and flush out old coffee from the spout. Otherwise the unit may need servicing to remove the clog as most of these capsule machines do not have serviceable parts. Contact your vendor or MFR directly for service or replacement.
*warning! Try not to stick a pin, nail, or paper clip into spout(s) as this may damage valve or offset the dual pour spout. Most of these machines have double spouts and can be easily pushed out of alignment.
* Final; I've noted that your probably using a portafilter type machine. If you have water or steam dripping from head then there is a leak in your head valve or commonly called the 'Group Valve'. Fortunately this is a serviceable part and can be replaced by your vendor.
PS. Have you tried 'Back Flushing? Use a "BLANK" portafilter basket (the one with no holes) or a back flush rubber stopper (from Cimbali). Add a 1/4 teaspoon of urn cleaner of flush cleaner to portafilter and lock onto group. Run shot till it stops (excess pressure and dose will by-pass the group valve. This will flush old coffee and crud out the by-pass pipe and into drain tray. If nothing happens and the group hums for longer than 20 seconds then your probably got a clogged valve and back flush pipe. All will need disassembly, cleaning and/or replacement. Best to call your Vendor for service.
*Be sure to run the group several times and wash the portafiler to get rid of the urn cleaner.
*Tip; It's a good idea to back flush every hour with with plain water from the shot to just get rid of the coffee grounds stuck to the group shower head and leftover coffee in the group valve. Does not hurt the machine and keeps everything working smoothly.
Aloha, youtube; ukeboy57
4helpful
2answers
Both spouts seem clogged
run vineger through it or CLR before they plug up completly. good luck
1helpful
Water not coming out of dispensing area, goes to drip tray instead Water comming out in drip tray instead of regular way
Try this, if the machine has a pregrind door(usually on the top front) then use the button to tell it you are using pre grind coffee, if water comes out the spout this way then the grind on the grinder is too fine, if it goes out the drain then the coffee passage is blocked, remove the brew unit and check/clear tubes, also clean the spouts on the door of the unit.
2helpful
2answers
Jura Impresso E9 not dripping through spouts but into drip tray
This is most likely due to a bad o'ring. The bar you speak of...Does the unit have a small spout pointing upward from the area?...with a groove? Is the o'ring in that groove damaged or missing? When the grounds are compressed in the piston, the brew unit lowers down onto this spout and seals on it. The high pressure water then is injected upward inot the brew unit. When this seal fails the water simply leaks into the tray when there are grounds providing backpressure. When rinsing and no backpressure some of the water may be getting through. Make sure you lube up any seals with a food grade lube. Olive oil will work in a pinch.
Mike
Coffee not dripping out of the machine
Top KitchenAid Coffee Makers & Espresso Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
