SOURCE: Onkyo remote RC 570M
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. - You can rate a solution with one of four
ratings as explained under (remember that at times a bit of to and fro dialogue
may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: Unlock code for jvc XV-N652
Below is the only known process to unlock that model of DVD player. Does not work on 100% of dvd players.
1. Turn on dvd player
2. Open the tray
3. Press 0000 in the Remote Controller
4. Change to any region you want (0 for region free)
5. Press Pause to confirm your change
6. Turn off
7. Turn on again and enjoy
Hope this works for yours, please post back if it does. Thank you for trying Fixya!
SOURCE: JVC dvd player model XV-N650 unlocking codes
From another site...
Region code hack posted by mairel, December 18 2007:
A
greeting to all, good after point to look for and to break the head, I
could convert to multizona my DVD, I count them that I stay fillet.
here they go them the procedures, I hope it serves them. 100%
guaranteed.
1. Turn on
2. Open the tray
3. Press 0000 in RC
4. Change to any region you want 0 for region free
5. Press Pause
6. Turn off
SOURCE: Region free code needed for JVC XV-N670B DVD
try this one, its not the exact model number but its close enough.
Open tray
Press 0 three times
Brings up a menu
Press 0 for the multi region
Press ENTER
Press PAUSE to exit.
hope this helps
Little Dish Fitter
SOURCE: remote control programming code for Samsung dvd-r155
OK, here are the Samsung VCR codes, from the orig. remote manual.
Samsung . .. .. .. . 057, 022, 024, 053
HOLD Power Button when slider shows mode of component you want to control.
PRESS 3 digit code (whole still holding power)
RELEASE power button...
To see if it worked, press and release the power button.
