Question about Frigidaire Washing Machines
Frigidaire affinity front loader washer still wont spin or agitate after replacing the door lock assembly. what should i check next?
Water works, and you can here the motor when it tries to spin. The belt is tight. tried all cycles does the same thing, no spin, no agitate?? Lynn
    Habit-Forming:
  • 107 Answers
Hi Lynn on machines like yours the drum itself in the back is what goes bad because it’s just a plastic piece like a washer/bolt those sheer off over time and go bad causing the washer to not be able to spin
Posted on Jan 14, 2019
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 152 Answers
Sounds like the brushes to me they are on the motor if worn the motor won’t turn
SOURCE:
  • 61 Answers
SOURCE: my frigidaire gallery front loader washing machine doesnt work.
Sounds like you have something in the pump and if there is a filter it might be dirty.
You will want to unplug the machine and take the back panel off and pull the pump out of the machine.You might want to take it outside an do this since there will be water in the machine and will make a mess.
If there is a filter it will be located behind the front panel below the door.There should be two or three screws that hold this panel on.They will be easy to access from the front with a screwdriver or a cordless drill and should be a #2 philips.
Posted on Oct 24, 2009
Jahn27
  • 1554 Answers
SOURCE: I have a frigidaire affinity front loader washer
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the electrical connections then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
Posted on Jul 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore front loader doesn't spin
Check the lid switch/ replace if necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
rabbitbrains
  • 575 Answers
SOURCE: my frigidaire affinity front load washer stopped spinning
Your door lock switch assembly has gone bad. It is an easy fix.
Posted on Sep 27, 2011
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: my frigidaire affinity front load washer ATF6000 will agitate but wont spin
    Hi burwellkaren - Is the washer making a humming noise? If so, either the drainage hose or pump is clogged and needs cleaning. If not, then the unit may possibly be experiencing an issue with the control board not communication correctly, faulty pump, timer, door lock assembly or something more severe like a damaged tub. I will personally recommend contacting a certified technician to narrow down the precise issue before investing in parts that may or may not be the root cause.
    Posted on Mar 11, 2013
    Why will my affinity front load washer not spin?
    No spin, try these:
    Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
    Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
    Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
    Next check for a loose, worn or broken belt if belt driven.
    On some front load models u may need to check the STATOR assembly.
    The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
    Apr 27, 2014 | Frigidaire Affinity ATF7000E Front Load...
    Frigidaire affinity not spinning
    No spin, try these:
    Apr 02, 2014 | Frigidaire Affinity ATF7000E Front Load...
    My frigidaire affinity front load washer ATF6000 will agitate but wont spin
    Mar 08, 2013 | Frigidaire ATF6000ES Front Load Washer
    Everything works but it does not spin
    There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue. Click on the link below for the complete and detailed procedure.
    Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
    Dec 29, 2010 | Frigidaire Affinity ATF7000E Front Load...
    I have the frigidare affinity front loader washer and just started it up. It stopped about 5 mins into the cycle and the indicator light says dr. I tried to shut the door but that didn't work. So I...
    You need to replace the door lock mechansim. Fairly easy to do yourself, just pull the spring strap off the rubber door gasket and remove 2 screws holding door lock. Install new door lock and re-install door gasket and spring strap, and WALLA! she works:)
    Nov 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
    I have a frigidaire affinity front loader washer that the final spin cycle won't work on. The rest of the wash cycle is fine and the basket spins for the other cycles just not the spin cycle. It is also...
    Jul 13, 2010 | Frigidaire ATF6000ES Front Load Washer
    My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
    If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
    Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
    My new Frigidair front loader
    Wow it sure sounded like the water was turned off. There should be no problem getting a tech out soon to see whats going on why it wont bring the water in. It sounds like maybe the door lock isnt working?? Is the strike broken on the door?? I take it it wont spin on its spin only cycle??just return it to place of purchase. If you need any other assistance let me know, reply to your old posts so i can be notified you wouls like more assistance.
    Jan 15, 2008 | Frigidaire ATF6000ES Front Load Washer
    Washing Machines Logo
    49 people viewed this question
    Top Frigidaire Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    J. Bradshaw
    Archie Ferrarini
    Archie Ferrarini
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
