Washing Machines Logo
Michael Giambrone Posted on Jan 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an LG tromm washing machine model number wm2277hw that goes out of balance and Shakes and bounces in spin cycle even after I replaced shocks Springs an. feet .
robert
Level 3:
  • LG Master 2,548 Answers
  • Posted on Jan 15, 2019
robert
LG Master
Level 3:
Answers
2548
Questions
0
Helped
869911
Points
8043
I suspect it your spyder. The triangle unit that attaches the inner drum to the hub. See if the inner tub wiggles without moving the outer drum. Answer back
Ann Masterson
Level 2:
New Friend:
  • Expert 152 Answers
  • Posted on Jan 14, 2019
Ann Masterson
Expert
Level 2:
New Friend:
Answers
152
Questions
Helped
46812
Points
227
How old is it if you have replaced shocks it’s probaly the bearings which is not an easy job to replace you have to strip it down to find bearing and replace bearing are cheap enough but it’s a long slow proscess not worthwhile getting somebody to do it for u it will cost 100 +
5 Related Answers
Anonymous
  • 11 Answers
  • Posted on May 20, 2007
SOURCE: Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
Anonymous
  • 10 Answers
  • Posted on Feb 12, 2008
SOURCE: Tromm Washer Model # WM2277HW by LG
will it spin after it washes if it does not then your belt might be broke
Anonymous
  • 156 Answers
  • Posted on Feb 25, 2008
SOURCE: spinning cycle
usey only takes about 2 tbs soap ather than that bad main board make sure you have cold water going in washer
Anonymous
  • Posted on May 07, 2009
SOURCE: Kenmore front loader goes off balance
My front load kenmore washer tub bounces really hard before going into a full spin. can anyone tell me what is wrong with this. thank you
Anonymous
  • Posted on Jun 20, 2009
SOURCE: I need the user manual for my lg tromm wm2277hw
for a drain and spin : turn unit on hit spin Button 1 time then start/pause button
this a drain and spin only..
2answers
My lg tromm wm2277hw Tub never balances and bounces in spin cycle
Probably suspension rods or shocks depending on design
My lg tromm model number wm2277hw/01 has the error code le show 2 seconds into the cycle even if nothing is in the washer what is going on
Hall sensor needs replacing (motor position sensor). Pretty easy and under$20. Check out appliancepartsproscom, repairclinic.com or YouTube for how to videos.
My lg tromm washer on the wash cycle is not spinning, and is making a grinding noise
check for something in the bowel. pins ,buttons coins etc have a technician check the spin operation.
2answers
LG Tromm WM2277HW
Does spin only work well?
1helpful
I have an lg washer wm2077cm and it goes off balance when the spinning cycle starts and the stops.
Sometimes if the heavy bed spreads or curtain may cause this problem. Switch OFF machine manually and restart after the spin stops.
If problem repeats.
Check springs or shock obsorber inside the machine. The tub will be suspended with this.
5helpful
4answers
LG wm2277hw front load shakes violently
Barry The repairman was right. The drum is out of balance because of the load amount .Thed clothes or items need to be distributed around the drom rather than just throwing in. When it comes to spin the imbalance causes the machine to shake and move across the laudry.
As it sometimes works This is probably when you are not doing a heavy load of washing, so it appears to work OK.
Pack it with less, also adjust the front legs a full turn higher than the rear so prevent walking when it spins.If you cant find the spanner that was included , just use an adjustable one.
2helpful
I need the user manual for my lg tromm wm2277hw because I don't know how to get it to spin without going through the whole wash cycle
1helpful
2answers
LG WM2277HW trouble
take off the front kick plate on the bottom and there is a pea trap thats conected to the pump twist it off and see if it is cloged thats what usaully makes it not spin
2helpful
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
