How to Change the Language in Netflix
Go to Netflix.com.
Select Manage Profiles.
Select the user profile that has the wrong language.
Select your preferred language from the drop-down menu.
Sign out and sign back in to save your new settings
SOURCE: GE 25861GE3 Answering Systems Plays Back Messages in Spanish. How do I change it back to English?
The solution that Best Solution gave worked for me to change it back to English. Thanks bunches!
SOURCE: Recorded programs in english come out in Spanish
Make sure your TV hasn't been set for SAP (you'll find it in the audio settings menu). Second audio programming is often used to carry alternate languages, and if it's turned on you won't know it until you watch a program where it's being used. There may be a single button labeled SAP on the remote. If so, it's easy to change the TV setting without realizing it.
SOURCE: how can i change my gmail from spanish back to english?
Login to your gmail account. On the right side you should see your e-mail address up top next to that is "Settings" (or whatever in spanish. Select that and on the first tab the first thing it shows you is language. Click the dropdown and change back to english.
SOURCE: MY PHONE CHANGED LANGUAGE FROM ENGLISH TO SPANISH...
All you have to do is start your menu from the begining, in timing advance to the language menu(if possible refer timing with the manual) scroll down and select- Anglais, press ok, there you are.
