SOURCE: Freezer not keeping things frozen
Hi Jody,
The only thing you give me that would allow me to solve this issue, is based on the fact that the freezer is getting warmer, and fresh food section is staying cold. So, knowing nothing more than that, I must sadly say that you need a new refrigerator to solve this issue 100%, as it sounds like you have a failing compressor, or a slow leak in the sealed system. Both scenarios are terminal.
Thank you for contacting me at Fixya.com
Dave E. (Illeagle)
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
SOURCE: Have a whirlpool top-mount fridge model # ET1FTTX00 the fridge
no frost in freezer temp is about 28 degrees in freezer
SOURCE: bottom freezer on Subzero refrigerator not thoroughly freezing
the aspiring air in the freezer botton don't work... sorry for english, i am french...t k
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
