Hi I have a Minolta zoom xi af 100 - 300 mm and it was dropped on the floor and now it will not be recognized by the camera and the front piece of the lens is loose like it has no control of zooming in or out. What is my problem?
SOURCE: Nikkor 18-200 mm VR with loose front ring and stuck zoom barrel
Unfortunately not. If the Nikon centre think it's been dropped, then you're stuck. They may well think so due to additional wear and damage caused as the initial fault progressed; this may well resemble the damage caused when a lens is dropped. You should really have sent it for repair as soon as the fault occurred.
All you can do is to write a letter of complaint to Nikon, asking them to intervene on your behalf with their authorised repair centre. It will help if you tell them how long you've been loyal to Nikon for and what other Nikon products you own; also state that if you must buy another lens that your money will instead go to one of their competitors instead and that when you replace your camera you will think hard before purchasing from Nikon again. It also helps if you tell them that you were well aware that you would be charged for any repairs caused by misuse, such as dropping your lens, and so would not have bothered to try and claim under warranty under such circumstances as it wasn't worth the risk of having to pay a big bill just to get a broken lens returned to you. Tell them that you have not dropped the lens and so you dispute their findings, and at the very least request that the lens is returned to you without charge so that you can get the lens examined by an independent repairer.
As long as your letter is polite, factual and states your argument clearly then you maximise your chances of getting them to revise their position to give you the benefit of any doubt.
Good luck.
Testimonial: "Good honest reply and very constructive ideas for what to include in a "polite letter of complaint"."
SOURCE: Tokina Zoom Lens
read this you will,automatically come to know
MINOLTA 16mm CAMERAS
From their modest beginnings after World War Two, the Minolta subminiature format rose to become the most popular Japanese 16mm, still-picture manufacturer and helped Minolta establish itself as a major player in the photographic industry. The revolutionary Minolta cassette is the closest the subminiature market ever came to a "standard" 16mm film format and it was copied by many other camera companies, even outside of Japan. With the exception of the Minox cassette, it is the long-distance runner of the submini world; Minolta manufactured and sold its film cassettes until 1995, and replicas are still being made in the Ukraine and China (?), today. Fortunately, even the older cameras are still very useable since the Minolta cassette used 16mm film (which is still readily available), and they did not require perforations in the film to advance the film. They are very easy to reload. Check out The Darkroom for details.
The original Minolta 16mm camera was designed by the Konan Institute and used the original Konan cassette. This cassette will not fit in any of the Minolta cameras -- or at least cameras with the Minolta name, since Minolta ended up making many cameras with the Konan name.
Basically, Minolta bought-out Konan. When Minolta took over, they redesigned the cassette using black felt for the light trap. There were actually several versions, nearly identical. The first was metal, but this was soon replaced with the more standard plastic type -- of which there were several versions. Minolta made two plastic models, identical except that on the second version a notch or indentation was cut into the cassette bridge to make it easier to break off the film take-up lobe for processing purposes. (If you have the newer version it's a good idea to fill in the notch with a little epoxy to make it last longer.) To complicate matters even more, similar cassettes were made by other companies, such as Yashica (which sold a camera that used the Minolta cassette), a company called FR (which sold the film and offered processing), and others. The Minolta cassettes are fairly easy to find today, and will fit in all of the cameras on this list. They will NOT fit in Mica and Konan.cameras.
To top it all off, there are even bogus Minolta cassettes being sold. For more information check out the NEWSTAND.
SOURCE: my camera dropped and both lens fell out need to reasemble
It does not pay to fix this camera. This camera can be bought on Amazon for about $55. A brand new camera with specifications that blow away the Olympus can be bought for less than $100.
Sorry for not instructing you on repairing this camera, but you won't find any reputable person that would repair it.
SOURCE: I have a Quantary zoom lens 28-90mm
Fitting is not always the solution. It is the software which recognises the hardware attachements. Either upgrade your camera software or use only the manufacturer recommended add ons. [email protected]
SOURCE: On a new Nikon 18-55mm
Nikon currently lists two 18-55 AF-S DX and two 55-200 AF-S DX lenses. One in each pair has vibration reduction, the other does not. The ones with VR in the name have it, otherwise it doesn't.
VR isn't exactly an option. If it wasn't built into the lens initially, you can't add it later. A lens either has it or it doesn't, though if a lens has VR it can be switched off.
