SOURCE: dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
SOURCE: AEG dishwasher 80850 code i30 reset
empty it, tip it on its back, mop up the spilt water, reload it and all should be ok. it is a recurring fault on our machine very irritating
SOURCE: Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
SOURCE: how can I reset an i30 (flood control) error?
you have to mopp up any water in the base of the machine. this can be caused by a leak . a sagging pressure pipe to the pressure switch can do it as well. you can tie it up to stop the sag. its at the front behind the plinth area.
SOURCE: Electrolux dishwasher ESF6242, 911 236
Hi
You have had a water overflow or leak which has triggered your flood switch. You need to disconnect the machine and pull it out. Throw plenty of towls on the floor and tilt machine back to empty the water from the base.
Hard to say where the overflow or leak is from. You need to reconnect machine while it is out of cabinet and run the machine to see if you can pin point a leak. Sometimes a burst drain hose.
Otherwise the front and side panels may need to be removed as the leak may be internal.
Other time a faulty PCB, faulty inlet solenoid which sticks or a faulty pressure switch or clogged pressure hose are the reasons for machine overflowing. Bad door seals can also cause machine to leak.
Therefore, there are a raft of items which can cause machine to overflow or leak.
Ash
Hello friend, I appreciate your inquiry!
Based off my understanding your dishwasher is displaying an error code of I30. An I30 error code means this could be an issue with your aqua control. I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to receive an I30 error code after the reset I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. Hopefully this information is helpful to you. -Matt
Hello friend, thanks for your inquiry!
On your Frigidaire dishwasher "i30" stands for aqua control. You should perform a reset on your dishwasher and that could clear any false error codes. To reset your dishwasher you can flip the household circuit breaker off for ten minutes. If that does not work you could be experiencing an issue with your water inlet valve or control panel. I hope this information has been helpful. -Matt
