I have been on all the forums to try and fix this issue and nothing has helped. I have used Canon and Sony cameras in the past and pictures come out crisp.
Setup your camera on a tripod and take test pictures. Make sure you use the same steady object so you'll be able to notice any differences. Use different modes and most of all use manual focus mode. Using this mode focus on the object take a picture and then take two pictures slightly off-focus (turn focus ring slightly to right and to the left of your first focus point) also make sure to use an open diaphragm to eliminate depth of field as much as posible. Compare the results, if one of the off-focus is sharper then your first on-focus your lens might have a problem, check the same procedure with another lens, if it happens again then it most probably is the camera sensor.
I hope this link helps:
https://www.youtube.com/watch?v=qtEBuuKImJY
SOURCE: Unable to download pictures from canon A530 digital camera
Try removing the memory card and inserting it again.
Also, does the computer detect the camera properly?
SOURCE: Blurry pictures in a Canon powershot SD400
The quality of photos has absolutely nothing to do with batteries and chargers, and very rarely with memory cards. If a salesperson tries to sell you one of the above, they're taking advantage of you!
First of all, make sure that the settings are appropriate for the lighting conditions of a given shot. Having a long exposure (e.g. 2 seconds) in daylight will produce blurry images that are overexposed (i.e. very white and washed out).
If you are positive that the settings are ok, and the problem persists even after changing modes (from auto to manual, etc), then try to use another memory card, or even the same, after formatting it and cleaning the contacts (with a dry fabric).
If the problem persists even then, you'd better send it for service
SOURCE: fuzzy pictures
The blurry pictures are due to movement. Sometimes adjusting the flash helps.
SOURCE: blurry pictures
This is the problem of the ZOOM in your camera. Its alignment is disturb by you. Your camera must have fallen down or some one has pressed the ZOOM from front when it was open. The solution is to get repaired at your nearest SONY service center.
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Also try to reset the camera back to factory defaults as there could be a setting that is causing the images to be blurry. To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset and press ok. Highlight yes and press ok. This will reset the camera back to factory settings. See if this clears up the blurry images.
