Question about HP Computers & Internet
My Hp pavilion 15 p249sa power light blinks only once and goes off. Nothing comes on.
  • HP Master
  • 3,917 Answers
No details in your post
no full symptoms.
I will just ask one question, and is a test of all laptops
1: remove the big battery and run only on the AC power pack., doing so is the screen still completely Dead.
no text, no HO ICON logo on screen?
Posted on Jan 13, 2019
  • 3 more comments
  • Sagabravo Jan 14, 2019
    Am still facing the problem. Is there any other way?
  • Anonymous Jan 14, 2019
    http://pcdied.com/dead-PC.html
    12 steps? easy to harder.
  • Anonymous Jan 16, 2019
    wny not answer the 3 questions above.?
    "Am still" does that tell me anything.
    pretend I cant see the PC nor see what you did,.
  • Sagabravo Jan 18, 2019
    When I put the battery inside it does the same thing. Power light blink once and goes off.
  • Larry Ng
    Larry Ng Jan 19, 2019
    but leave the battery out, (large)_
    run On AC power pack only.
    the big batteries, love to fail and worse short out and become a huge power drain.
    so we first run all laptops made, with no battery large, see?
    is the screen now (no battery) still 100% dead
    no text?
    no logo icon HP
    no prompts.?
    New Friend:
  • 58 Answers
Step 1:
disconnect all external devices including battery & AC adapter
Press and hold the power button for 10 seconds to discharge any or all static from the PC.
Step 2:
Connect back the battery & AC adapter
press the windows key + B and at the same time press the power button.
This should clear the BIOS (Incase of BIOS issues or interrupted updates)
  • 1 more comment
  • Anonymous Jan 13, 2019
    #1 cause of problems with things like this
    that big battery fails.
    and reloading BIOS is silly. to a fault;
    why have them make it worse compounding the problems.>
    the screen is dead, work just that hard failure. (first)
    if there is power problem in any PC
    the last thing ever to do (dont) is to do the HP windows +B BIOS recovery.
    scrambling it. (hardware rules)
    if already scrambled the BIOS , sure.
  • Sagabravo Jan 17, 2019
    Nothing comes. No screen nothing at all. It only flash once and go off. Only the fan spin then it stops
  • Larry Ng
    the PC has power problems.
    first off , did lose the AC power pack?
    did you use that? plug in both ends
    and run on AC pack with the now bad large battery removed,
    The battery is this all time #1 first item to fail. so we test the laptop ,
    no battery
    and only AC power pack as our power source
    this is very simple to do, takes 1 minutes,work; please do that and report the results. thanks
SOURCE:
kgjsm397
  • 105 Answers
SOURCE: blinking green light on the back of hp pavilion
1. Your smps is OK for power supply
2. check the beep sound for RAM and Video card (If it is long beep the RAM is having and short and frequent the Video card) o
3. Remove RAM then start ssytem see the response shoutdown, clean the RAM place it back start the ssytem
4. Remove the CMOS battery or short the jumber for any setting in BIOS start the ssytem
5. Disconnect all the cables connecting motherboard including Hard disk except SMPS power supply to Mother board
Posted on Jun 22, 2008
jtuckerj
  • 59 Answers
SOURCE: HP computer doesn't turn on
Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
Posted on Dec 12, 2008
  • 79 Answers
SOURCE: Flickering green light on power supply
power units not working,, the light means power problem you will need to replace the power supplie
Posted on Apr 23, 2009
  • 788 Answers
SOURCE: hp pavilion dv5 wont start. the monitor remains
This unit should still be in warranty. If out of the first year warranty, HP has extended the warranty program for Video issues for a extra year from date of purchase.
Register your unit with HP, if not already and email customer care and log your video issue, ASAP.
I hope this has helped you.
Posted on Oct 07, 2009
nicoleFIXIT
  • 154 Answers
SOURCE: HP Pavilion dv6636nr boot problem
When we talk about laptop won't boot up it is a hardware failure.
First of all, most of the hardware failures that are going to be presented in this article require you to disassemble the laptop and work on its internal components. Because of this, you need the required components to take the laptop apart (such as screwdrivers, etc.) and space, lots of space. If you don't have a workbench, then working on that large table in the living room should do it.
Second of all, you need to be extra careful about ESD (electrostatic discharge). Sure, this is important when working with a desktop system too, but you really shouldn't consider this as some sort of overreaction or waste of time. A few anti-static conductive bags should suffice. These are going to be useful when you take apart components from the laptop and you need a safe place to put them down.
If the laptop does not power on using the batteries, then try to power it using the AC adapter. Pay attention and see whether the LED on the laptop lights up, signaling that the adapter was detected. If yes, then your power jack works. If the notebook still does not power on, disassemble the laptop and remove the batteries. Look first for the CMOS battery and take it out.
Your best bet is that the problem is memory-related. What you need to do is re-seat the memory modules. If there are more than one, then try swapping them between each other and try different slots. Try booting again. If it does not work, then try running with only one module - this way, you can tell whether one is faulty.
Disassemble the laptop and remove the HDD, CD/DVD drives, and the modem and/or wireless card(s). If possible, take out the sound card module (if separate). To minimize the possible causes, you may disconnect the LCD panel as well. Try running this way. If it does boot, then try connecting each connector one at a time, booting up in between to localize the problem.
Good luck and take time to do a hard troubleshooting this trouble is not easy as well. You need to be care full in removing the some parts so that the other will not affected and being damaged.
Posted on Dec 02, 2009
Testimonial: "thanks! i was not waiting long enough before replacing the cmos battery back in its slot. after a ten minute wait, it did the trick. you rock."
Hp pavilion slimline power supply
you bringing a marginal part or connection back up a working state. when it cools or voltage drops it goes to the non working state. hp power supplies are not good to begin with. replacing it will fix it till that one also fails
May 23, 2017 | Computers & Internet
New DC jack, powers up but no display. Strange power LED behavior.
No Rob, you aren't running out of options. You just haven't diagnosed far enough, because you don't know the path.........hence where I come in.........
Using the HP Pavilion dv6000 series, and Pavilion dv9000 series of Notebook PC's, as an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
There are two Power MOSFET's being used.
The Fairchild Semiconductor Industries - FDS6679 - Power MOSFET, and the Alpha & Omega Semiconductor LTD - AO4407 Power MOSFET.
Both of these P.MOSFET's are Obsolete. However there are cross reference examples given. Let's look at two of these examples, and also note the cost,
http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/FDS6679AZ/?qs=sGAEpiMZZMshyDBzk1%2fWi1qxDdW%2fXBi2qgMuZEfLVO4%3d
One dollar and one penny - USD
http://www.mouser.com/ProductDetail/Diodes-Inc/DMP3020LSS-13/?qs=%2fha2pyFadujguNNSgppBRqXbOxXLwzGsZm9SWxz1EqWpzoSJOpHpWA%3d%3d
78 cents - USD
Surface mount soldering 101,
http://www.youtube.com/watch?v=3NN7UGWYmBY
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 22, 2013 | HP Hewlett Packard ALL-IN-ONE-TouchSmart...
My hp pavilion dv6000 does not turn on power button just blinks and goes back off
For this problem, I'd check to see if are you getting the correct voltage out of your power adapter? It should be about 18v.
Try turning it on with the battery and without the battery.
If the computer has been working, it could be that the battery is dead and the DC jack that passes power from the adapter to the computer is loose. Try wiggling is a little and see if the power light comes on.
I think that the problem is you are not getting power to the system and this is why you get a brief flash and nothing else.
May 25, 2011 | HP Pavilion dv6000z Notebook
I cant turn on my HP520 notebook pc. when i press the power button, it blinks once, and the charging light blinks for 9times(orange light, the 8th times was green light) i tried to remove the battery and...
Alright, not sure if this will help, by my understanding is that you are saying that when you power the computer using the power supply adapter, nothing comes on? Then when you have your battery installed on, then there are lights blinking from your battery charger LED amount of times. In this case there are no promblem with your laptop and it is your power supply adapter that is damaged and will need to be replaced. It is not charging the battery. The battery is still good, but does not have enought charge to power up your system. You can find a charger on ebay for a good reasonable price compare to getting it from Hp. I hope this can help you.
Jan 13, 2011 | Computers & Internet
My HP dv4 1120us laptop will not power on. When I insert the power cord the led for power bolt comes on and when I press the power button the power LED flashes once and then nothing happens. The power bolt...
Sounds light a power switch short, but lets try to take the memory out of the laptop and power on the laptop. Does it boot up? if so lets try 1 memory stick at a time.
Nov 29, 2010 | HP Pavilion dv4-1120us Notebook
My HP Pavilion Entertainment Laptop won't turn on. The power indicator light blinks briefly when I press the power button, but it does not boot up.
Does the power indicator lit permenantly? If it glows for a short time and then goes off, then it is due to a faulty component on the motherboard and u have nothing to do if you are not a laptop technician. Make a reply for this.
Apr 13, 2010 | HP Computers & Internet
Hp Pavillion Tx1320us..wont boot up
You're probably one of thousands of victims of defective nvidia chipsets in these systems. Call HP and complain.
Jun 08, 2009 | HP Pavilion TX1320US Tablet PC
Computers & Internet Logo
60 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
