SOURCE: refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
SOURCE: bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
Sounds like a defrost problem. Check to see if
there is any frost buildup in the back wall of the freezer. If so, it is not
defrosting as it should.
If
you don’t know what these are then unplug the machine and let the ice melt in
the freezer overnight with the door open. Then try it the next day, if is
cooling fine then you need to have a service person replace one of the above
items. If it still has a problem then it might be the compressor and you should
probably replace the machine.
SOURCE: Refrigerator freezing up and fan catching
From your information Bill it seems the defrost system has failed. There are several componants that could cause this. First check the defrost heater which is located on the evaporator. You will need to pull the plug and let the ice melt completely first. Store your perishables elsewhere.
With an ohmmeter, check for continuity across the defrost heater. With all due respect, if this is confusing you need to call a service tech. If you have continuity across the heater, check the defrost thermostat which is a round disc fastened to the evaporator.
Finally, look for the defrost relay. It should be found somewhere on the lower rear of the refrigerator. Check for power to the relay, and on the outlet side. A wiring diagram located on the back of the unit will help you find the correct wires. All of these parts should be available from your local refrigerator parts supply, or check with Samsung online to order. Be advised Bill that this is not a simple repair, but if you have some electrical understanding, you can do it.
Ray
SOURCE: Bosch Refrigerator ice forming in vegetable drawer
Emptied drawers and cleared the drain hole. Drawers were then refilled BUT MADE SURE THAT THEY WERE NOT OVERLOADED
SOURCE: freezer is making frost, fridge side doesn;t seem
The problem is most likely either the defrost timer, and/or the defrost heater element(s) are faulty. The problem is actually that the defrost heater elements are not functioning properly and the evaporator core is actually freezing up and blocking the air flow through the evaporator core and also freezing up the thermal sensor, and when that happens there is no longer enough cold air being circulated through the refrigerator (that is actually how the unit operates and air must be able to flow through the evaporator core and then be circulated throughout the refrigerator to properly function) and as a result the refrigerator stops functioning and food can even thaw out in the freezer although the freezer seems to be iced up. (Usually at the rear wall where the evaporator core is located)
(Air flow through the evaporator core and cold air circulation and re-circulation through the refrigerator is performed by the air circulation fan and it also must be functioning)
Be sure to only use a blow dryer (with a towel on the bottom of the freezer) to thaw out the evaporator core and do not use any hard or sharp objects or the evaporator core can be damaged. The defrost timer can be located inside of the refrigerator itself, (see lower image) or it can be mounted outside usually either behind the air intake cowl or kick panel at the front base of the refrigerator, or most likely located behind the service panel on the rear of the refrigerator, and usually if the defrost timer is turning then it is most likely working, however the defrost timer can move very slowly and you can place a mark on the timer and the housing to check after about fifteen minutes to see if the position on the defrost timer has changed. The deforst timer on newer digital models can be built into the circuit board and is not a seperate timer mechanism. The defrost heater coils can easily be checked by dis-connecting them and using an ohm meter, and a high or an infinite reading would indicate a faulty heater coil, however most of the time they are easily identified as being bad just by looking at them.
Here are some images that should be similar to your situation to help assist you, and let me know if you require any further assistance.
Hello friend, thanks for your inquiry!
I understand that you have a Frigidaire refrigerator, FGHN2866PF1, and your deli drawer is freezing items. You may want to turn down the temperature within your deli drawer, when adjusting the temperature could take 24 hours for your refrigerator to stabilize. If that does not resolve your issue I would suggest removing the drawer and checking over to make sure there are no cracks where too much air may be coming in. If there is too much weight in the deli drawer that could cause the drawer to sag, which may release cold air into the deli drawer. I hope this information has been helpfu. -Matt
