Shirley Turner Posted on Jan 13, 2019
THE SIGN F61 IS DISPAYED AND MACHINE WILL NOT START
Replaced the side fan with the factory part. Now get an f61 error. reconnecting the old fan correects the f61 error. What can be done?
return the new fan as defective and start again with another and mention your issue, either new fan bad or wrong one.
Bosch soccer edition error F61 coming
bosch soccer edition washing machine model :WAE24467ME This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
3helpful
2answers
F61
That code means the audio amplifier IC´s are dameged and need to be replaced
Code F61 when setting up
CHECK THE FAN,IF OK THEN YOU HAVE A PROBLEM WITH THE AUDIO STAGE
Abs warning light on traction control fault dispayed,battery power drain when attempting to start,engine starts then cuts out and alarm sounds
Check for short in the electrical system as that is what is causing the Drain , then check if the Generator is working properly
Do not know where to hook - cable to charge battery in bmw 540
THERE SHOULD BE AN AVAILABLE CONNECTION UNDER THE HOOD ITS LIKE A BIG BOLT WITH A COVER WITH A PLUS SIGN, SOME ARE BY THE INTAKE SOME ON THE FIREWALL .
1helpful
2answers
Panasonic home theater sa-ht920
Although the Panasonic Home Theater systems are great when they work properly. If your machine displays the "f61" error message, it's likely to be little more than a paper weight for the average person. The inner workings of the machine are rather complex to disassemble for diagnostics. And can take several hours to check all the components. The best advice I can give you is to sell the machine on e-bay as a broken item. If you offer shipping you can get more money for a complete system (speakers & all).
F61
The F61 is a shorthand for protection mode. This means that a problem was detected and the unit shutdown to prevent further damage. If you can post the model number, I can provide the part number and cost.
Dan
6helpful
3answers
F61 fault
2helpful
4answers
Error F61
I have just struck this problem on a friends unit and here is what I did
Disconnect DVD player and all accessories and connections
Problem still occurs
Open machine ( remove three screws from back and slide top cover off. inspection of the inside top cover shows a black patch just above the fan unit
manually spin fan
power up unit and f61 no longer shows up
I think this miaght be a problem with the fan not spinning up at start and the machine then shuting down
I will fit a new fan and see what happens
Top The Audio Players & Recorders Experts
vince
Paul Carew
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
