Washer filled then washed and when it got to rinse cycle made a loud knockinG noise then quit now nothing no sound or nothin
    Master:
  • Washing Mach... Master
  • 640 Answers
Jammed or faulty pump
Posted on Jan 19, 2019
  • 351 Answers
SOURCE: 7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Posted on Mar 04, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Posted on Nov 20, 2008
  • 85 Answers
SOURCE: KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Posted on Dec 21, 2008
  • 563 Answers
SOURCE: Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
No longer "ultra quiet" huh?
A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
Posted on Aug 30, 2009
SOURCE: loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Posted on Apr 16, 2011
Whirlpool top loader: very loud pumping sounds when filling
You are experiencing surge pressure due to the ATC. It is increasing then reducing the hot water slow to maintain a pre-determined temperature.
I am not aware of a disable or bypass procedure.
Sep 05, 2009 | Kenmore 22422 Top Load Washer
My kenmore HE 2 Plus washing machine makes a loud grinding noise when it enters the pre-wash/wash cycle (worse on this cycle) then continues on through the rest of the cycles. Washer fills, rinses, spins...
Unfortunately, I don't think you will be able to fix this issue, some mechanical parts are breaking. If your appliance still under warranty, you may need to contact the appliance manufacturer for assistance. This kind of repair can be expensive and is difficult enough so a service technician may need to fix it.
Aug 31, 2009 | Kenmore HE2 Plus Front Load Washer
Agitator on maytag sav2555aww won't spin, loud clicking noise
I just replaced the trans in my maytag.if the washer is less than 5 years old trans is covered under warranty. but here is the kicker, labor and thrush bearing is not. trans cost is about 300.00 and labor is about the same. a new washer is about 450.00 So if you know someone who can do trans.[like for free] if not buy a new one. Good Luck
May 21, 2009 | Maytag SAV2655A Top Load Washer
Kenmore dishwasher has loud noise during fill. If you let it go, the washer fills. Once filled, noise stops and wash cycle continues. Sounds like plumbing does when there is air in the pipes. Not a...
This isn't a solution but rather a comment, if the problem is happening only during the fill, then it could be the water inlet valve. Perhaps there is a soliniod going in the valve, watch to see if the fill cycle starts to dimminish over time. Does the sound come anytime the washer fills, ie: rinse cycle? if so I would replace the valve, probably 50 dollars would get you a new one and you can do it yourself to save a little more cash. good luck.
Apr 19, 2009 | Kenmore Dishwashers
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Whirlpool washer Mod# TWAS750PQO, Ser# CR3520005
is it possible that the washer was overloaded? if so the agitator has little plastic "gears" that move the agitator one way only, they could have made the sound.
you can also check under the washer to see if anything (like a coat-hanger or something) is interfering with moving parts of the washer
Jun 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Bad noise at begining of rinse cycle.
It sounds like your gear case (transmission) has gone bad. If the washer fills and agitates that tells me that the problem cannot be with the motor coupling and drive motor. It also rules out a pump problem if the washer completes a wash cycle and drains properly. The only thing left is the gears inside the transmission. Sometimes they go bad in a way that portions of the wash will work while others don't. The part number is 3360629 and the price usually runs about $150. I hope this may help you in some way.
Sep 22, 2007 | Whirlpool LSR5132PQ Top Load Washer
Will not agitate or spin,makes loud noise during those cycles
Sounds like coupling gears between transmission and motor... they did away with the belt and went direct drive with coupling gears. It can pump water out but nothing else. water pump is mounted to front of motor is why it will pump water out.
Jun 19, 2006 | Whirlpool LSN2000LW Washer
Open Questions:
Washing Machines Logo
1,166 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
