If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://homenol.blogspot.com/
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
{View the site in web view or by a desktop to see the search box. Mobile view has no search box.}/
SOURCE: Problem to program my remote control
Try using the guide to help you with this problemm if you dont have one, try going to a local store that sells this product.
SOURCE: My 42 inch Haier Plasma has a no signal on screen
i had the same problem and i bought the new remote control and it did work at first i thought it was going to do the same thing but then i pushed the tv/use button and it worked perfectly.
SOURCE: REmote control RM-C1257G not working even after trying new batteries
Try this
1. Get camera phone
2. set camera phone to to take picture
3. point remote at camera and look at the camera display
4. press buttons on the remote, you should a light from the Remotes IR.
5a. If NO light is seen, your remote is broken. you can try replacing the batteries to double check
5b. if Yes, light is seen. Your remote is working and you may have a problem with the TV.
As a double check, get a remote you know is working and try the same thing to verify that you are checking the remotes correctly.
SOURCE: remote control not working on brand new series 4 42 inch samsung
Make sure the remote is set to operate your tv and not a cable box or accesory. It's in the menu
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
