Question about Casio Music
Casio Celviano Ap420 - Metallic G
G above middle C frequently (about half of the time) plays with a strange tone. It sounds as if the hammer has been compacted or if a tack were place on the hammer before striking the strings. Of course, there is no hammer and no strings, so... Usually more of a problem when playing the key louder. Tried a factory reset, but no help. Only the one note, too, but I like playing in G and C and D and Eb, etc.
SOURCE:
  • 10 Answers
SOURCE: EWI4000s only plays one note
Hello a_marechalro,
You can try to reset your instrument.
Turn off the EWI,
Press the LEVEL, FX, SETUP and TRANS buttons.
Then turn on the EWI.
This is a Factory reset.
I hope for You this is the solution.
Kind regards,
Fred Roubos.
Posted on Dec 27, 2008
  • 1140 Answers
SOURCE: MIDI Keyboard note delay problem, not latency problem PLEASE HELP
You are suffering from midi latency. There is a good article about this at www.thewhippinpost.co.uk/latency.htm There is also some good advice there.
Posted on Jun 23, 2009
  • 5603 Answers
SOURCE: My Roland Rd-500 has no sound....the factory demo
You either did not get the ribbon cable seated OR got it upside down.
If this cable is the flat ribbon with exposed solder plated points of contact, OFTEN those connectors have a latch to release by GENTLY moving tabs on eaither side in the direction of pulling the cable out. This lock MUST be moved out slightly to allow the cable to seat properly. The solder plated contacts will be FULLY into the connector when seated properly.
These cables ALSO can be inserted backwards and NO connection will be made.
Posted on Feb 14, 2010
SOURCE: HI there, I Have a casio cz1 synthesizer, great
I had a similar thing happen.
Definitely change the internal battery and initialize back to factory settings. Just hold down the red initialize button (top right hand corner) while you turn it on. It will then ask on the LCD - hit "yes".
I also had to change the battery in my external cartridge (if you have one).
There are some great (free & pay for) sound patches on the web for the CZ1 (way better than the presets) you can load them in via midi sysex.
Posted on Jul 24, 2010
  • 5603 Answers
SOURCE: Brand new AKAI EWI 4000S was playing great for 30
This sounds like a power supply issue... Since the unit is new, make use of the warranty for repair or replacement.
Posted on Oct 30, 2010
Connecting to garageband
Only newer models with class-compliant USB (made last 12 months) can connect to MACs - & IPADs and PCs.
Older models require drivers available only for Windows.
Mar 13, 2014 | Casio Celviano AP-220 Digital Piano...
Casio piano seems to be frozen
It is 3 years/5 years warranty depending on your country.
Call CASIO warranty or contact dealer.
Feb 16, 2014 | Casio Celviano Ap420 Ap-420 Home Digital...
My Casio AP 620 Celviano says "Loading" soon as I switch it on but is not working
Could possibly power supply problem. If you're running through a multi-board, try running directly into the outlet. Failing that, try another power outlet altogether.
The Celviano range aren't real power hoggers once going, but initialising and starting up takes a bit of omph.
Sep 09, 2013 | Casio AP-620 Celviano Digital Piano
Casio keyboard 465 sound tone bank ct638 manual
I have a 465 sound Tone Bank Casio piano that was dropped and now it doesn't work. I'm not sure what the problem is.
Jan 16, 2012 | Casio Music
I have casio CTK 5000. i want to download additional tones and rhythms on it . kindly suggest the site as well as the file formats it will recognize for this model. also kindly describe the total procedure...
It is possible to load new rhythms and tones in the CTK-5000. But you need the stuff. That is what it really lacks. Casio needs the Rhythms and tones in its own formats.
May 15, 2011 | Casio CTK5000 (61Key Portable Keyboard)
Casio tonebank ct700 no sound from chords only whilest on fingered chord please advise
More info. If you are chording on the left half of the keyboard, SOMETIMES they allocate or have the option to select a different voice for the part where chords are played. For these, you have to ALSO select a voice for that half of the keyboard. If you don't select a voice, then you would not have anything sounding.
Sep 27, 2009 | Casio Music
Music Logo
54 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
