Question about Frigidaire Kitchen Ranges
Island hood installation instructions for Frigidaire island hood
    Top Expert:
  • Frigidaire Master
  • 30,680 Answers
Id try their website.
Posted on Jan 12, 2019
3 Suggested Answers
SOURCE:
  • 10865 Answers
SOURCE: installing a vent hood...
There is no kit to make this conversion. That being said, you could get an estimate from a sheet metal fabrication shop on creating the conversion you are seeking.
Good luck with it.
Posted on Feb 13, 2009
  • 11 Answers
SOURCE: can this be installed over an island?
Bring a focal point to your kitchen by having an island range hood, combining function and elegant form. A suspended hood is also an efficient way to vent
grease, odors and smoke to the outside from a island stovetop while you cook. You can install an island range hood in just a few hours with the right tools
and knowledge.
1.Wear safety glasses and work gloves. Turn off the electricity to your kitchen at the circuit panel. Cover the circuit breaker with a piece of electrical
tape to prevent people from turning the on switch while you are at work.
2.Lay work drop cloths on your cooktop and floor to catch dust and debris. Mark the duct opening with a pencil in the ceiling, where the island hood will be
installed. Be sure the opening is centered directly above your cooktop. Cut the opening using a hacksaw.
3.Go up to the roof, using a cat's claw and hammer to remove stucco, tiles, sheathing and insulation to make way for the steel venting duct. Drop a
plumb bob down the roof, making sure the line is straight down for the ductwork.
4.Follow the manufacturer's instructions for locations, installing 2-by-2 wooden blocks in the ceiling to hold the ductwork hangers.
5.Install the venting duct from the outside of the home, down to the location of the exhaust vents on the island hood. The ducts should easily slip into each
other. Secure all the duct sections with duct sealing putty, using a putty knife.
6.Screw a roof cap on the end of the duct at the roof. Seal any openings or gaps where the roof, ceiling and duct meet with silicon sealant. Let the sealant
dry, then paint with colors matched to the surrounds.
7.Place your hood upside-down on the floor, with the fan and filter facing upward. Locate and unscrew the metal electrical box cover on the island range
hood, to expose the wiring
8.Install the hood cover to the load-bearing ceiling frame with the package hardware through the four inside mounting corner flanges on the cover.
9.Measure what will be the distance from the bottom of your hood to the cooktop; it should not exceed 30 inches for exhaust efficiency. Have a helper hold
the hood in place while you attach the hood on the hood cover using the included screws. Use a level be sure the hood is level as mounted.
10.Connect the electrical wiring by consulting the manufacturer's suggestions or hire an electrician if you are not familiar with house wiring. Tuck the wires neatly in the hood electrical box and then replace the cover, after connecting the hood wires to the wall wiring.
11.Remove the electrical tape on the circuit breaker, turn on the electricity to your kitchen and test your island range hood.
Posted on Aug 09, 2012
IF I HAVE A BLOWN TRANSFORMER, WHERE IS IT LOCATED OR WHAT DO IT LOOK LIKE??
Thank you for your inquiry, Glory Barnett!
I understand that you are seeking the location of your transformer within your Electrolux range hood. I was able to locate your parts manual for your range hood on page two, part number 208 (5304455011). I hope this information is helpful to some degree. -Matt
Frigidaire Manual Search Results
Nov 03, 2014 | Electrolux E36PC75GSS Stainless Steel Icon...
Can this be installed over an island?
and knowledge.
May 26, 2009 | KitchenAid KHVU781RSS Stainless Steel...
Installing a vent hood...
Good luck with it.
Feb 13, 2009 | Frigidaire PLHV36W7CC Kitchen Hood
Futuro Island Vent Hood
Hi snuds1369,
I'm Harvey the Master Plumber.
Your question is: You have a situation that recently has started with your Futuro Island Vent Hood. In the past a blue light would be on the display (4 buttons) when the hood was on. Recently the blue light for the hood is now on when the hood is off. Is there a way to reset this?
Yes. Turn off at the breaker for 30 min. If this doesn't work it's an indication the control chip has a problem.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 12, 2008 | Futuro Kitchen Ranges
ZV800SJSS GE Monogram
most normal hoods cost about $60.00 to $100.00
Jun 10, 2008 | GE Monogram ZV1050SFSS 42" Island Chimney...
Does a oven range fan have to be on its own circut?
According to the manufacture instructions, you always need to run any appliance on it's own circuit. Any licensed electrician will tell you to run another circuit. We have to cover our butts you know.
That being said, I have my range hood running on a shared circuit with my porch and attic lights and one outside receptacle.
It mostly depends on what else you are running on that circuit. If you already have several things on it that you would have running at the same time as the hood I would recommend running another circuit.
Nov 17, 2007 | Kitchen Ranges
Kitchen Ranges Logo
47 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
