Question about NordicTrack Exercise & Fitness
I have a nordictrack elliptical model 24032. how can I replace the drive belt?
    Top Expert:
  • 4,424 Answers
Your manual may have the instructions
http://www.manualsonline.com/
Posted on Feb 28, 2019
SOURCE:
  • 15 Answers
SOURCE: replacing the drive belt Nordictrack
basically you will be just about to take your treadmill, almost totally apart. But the are not many nuts and bolts to solving your problem, first Lay treadmill on its side and locate the rear roller bolts, on mine their are 2, most tread mills are all the same, remove them 2 bolts, Now locate the front roller bolt, 1 bolt,remove bolt, your belt is going to be very loose now, on the side that you would be walking on, Is a board, 6 phillips head screws, Hold the board to the metal frame, remove them, remove the board, then go back to the rear roller, And remove the plastic end caps that hold the rear roller too the metal frame, by gently tapping them off, remove old belt from rear roller, Now go to front roller, and remove belt from front roller, and its time to Install new Belt, AND AJUST NEW BELT, Put belt on front roller and reinstall roller, put plastic end caps back on frame, and then reinstall rear roller threw the belt and reconnect to the plastic end caps on the rear of the frame, Now reinstall the board with 6 phillip screws, to the metal frame, Now turn treadmill upright again, Its time to AJUST YOUR NEW BELT 1st Center your New Belt, Then tighten rear roller bolts, ( Pay Attention ) Count even amount of turns for both Rear roller bolts, Then Ajust front roller Alignment, Their is only 1 bolt on most treadmills, So if your belt is pulling to one side when you turn the treadmill on,it means you still have to ajust the front roller ajustment screw, What I Do Is , I USE A small leveling tool, For the front roller ajustment, It KEEPS the pitch EVEN on both sides of the front roller, and this is HOW YOU REPLACE YOUR BELT AND AJUST THE NEW BELT, and save your self some money, enjoy, in you need to contact me, kjosr@cox.net
Posted on Oct 25, 2010
Robert Braun
  • 77 Answers
SOURCE: How do you replace the drive belt on a Nordictrack
You get full installation instructions when you order through Treadmill Parts.
Posted on Oct 30, 2011
  • 95 Answers
SOURCE: Need to replace the drive belt on my Weslo Momentum 610 elliptical
Which version of the Momentum 610 do you have? Here is a drive belt for the WLEL14051 and WLEL14052. There are a few slightly different model numbers for the Momentum 610 listed here that do not have drive belts listed in their parts list, so it is possible that the first link works for those two, but I could contact them to make sure.
Posted on May 01, 2012
ercupa190
  • 12223 Answers
SOURCE: My NordicTrack E5 vi Elliptical is squeaking really bad. How do I fix this problem?
go to :http://www.ehow.com/how_4681374_fix-elliptical-machine.html
God bless you
Posted on Jun 09, 2012
ercupa190
  • 12223 Answers
SOURCE: Nordictrack Asr 1000 Elliptical Resistance Motor
1) Adjust the cable tension
2) Adjust the magnet, for loose bolt, test the magnet with the refrigerator magnet, for repulsion and attraction, Replace if necessary buying in any Hardware store, for small price.
God bless you
Posted on Jun 11, 2012
My Nordictrack elliptical model 23907.0 used to turn the display off automatically after so long of not being in use. How do I turn this feature on again?
How to Replace an Elliptical Console
Please see the video, and follow the steps.
However clean very well the spring with electronic cleaner contacts, and see if the wires are o.k or loose or desolder and repair.
Use ALKALINES batteries for Heavy duty.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 23, 2017 | NordicTrack Exercise & Fitness
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Jan 05, 2016 | Exercise & Fitness
Why is my elliptical not gliding smoothly?
I do not know anything about your machine. But from a general mechanical standpoint. It sounds as if the belt is not routed properly, or is the wrong size. You can also inspect where the belt rides for debris from the old belt. Something could be stuck somewhere. Hope this helps. Good Luck!
Jun 10, 2014 | Nordic Track NordicTrack AudioStrider 990...
Extreme noise in elliptical when using
With regard to the clunking in the NordicTrack E7sv it turned out to be the left side wheel to crankshaft connection. It had come loose. I removed the left side foot rods and wheel cover plate for access. I re-seated the wheel on the shaft and tightened the hardware. Noise gone. So is all the squeaking associated with it loosening.
Jan 03, 2014 | Nordic Track Nordictrack E7 Sv Nordictrack...
My 390 E is locked up and I can't move the pedals. I checked the belt, it's still on and it's tight.
follow this steps and fix it. God bless you
Electronics Problem You control the tension of the pedals using the buttons on the console. When you assemble the A.C.T. elliptical, you have to thread a group of wires from the console through the upright down to the electronics board. These wires communicate the resistance settings to the electronics board. If the wires twist, disconnect or break, the resistance will not work. You will need to reconnect or replace the wires.
Read more: http://www.livestrong.com/article/406522-tension-problems-with-the-nordictrack-a-c-t-elliptical/#ixzz2Z4kLeLBm
Jul 14, 2013 | Proform PFTL79807 - 850 W/ Gamefit...
My NordicTrack E5.7 Elliptical is making a grinding sound
Hi Liz,
The only way to assess is to take the covers off. There are a few reasons for this type of problem.
Nov 07, 2012 | Nordic Track NordicTrack E5.7 Elliptical
Apr 30, 2012 | Weslo Exercise & Fitness
Nordic Track elliptical E7: The tension belt came off. It's not apparent how it goes back. Are there diagrams that show the way the belt is attached to the tension cable?
If you are looking at right hand side of unit you have the flywheel next to it adjusting tension plate.If you have your manual handy it will show how to loosen this part so you may loop over the small idler pulley which goes around the much larger pulley wheel if not here is the web page to go to and its on page 21 Hope this nugget will help!
http://www.iconservice.com/CustomerService/manualsProductManuals.do?model=NTEL07808&version=0&company=11&modelName=NORDICTRACK+E7+SV+FRONT+DRIVE+ELLIPTICAL&language=
Apr 06, 2010 | Endurance E7 Elliptical Trainer
Exercise & Fitness Logo
73 people viewed this question
Top NordicTrack Exercise & Fitness Experts
Craig Butler
Craig Butler
Ross Metcalfe
Ross Metcalfe
Kardoc
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
