SOURCE: Toyota 1985 22r pickup starts runs 2 secs dies starts runs 2min dies over & over
Check your plugs and distributer timing. Maybe try running some seafoam through your injectors.
SOURCE: car starts but dies after 2 or 3 seconds
try replacing the throttle positioning sensor its on the throttle body
SOURCE: snow blower starts right up but dies once i engage the blades?
it is possible the engine is starving for fuel, so essentially it is a carburetor problem with fuel mixture.
Check and see if your carburetor has mixture adjustment needles, there may be an adjustment possible to fix this problem.
Also, sometimes a tiny vent hole in the carb caseing gets clogged causing the engine to run rough or stall.
Does your engine seem to run better if you close the Choke ?
Hope this helps you.
SOURCE: 1985 Corvette, starts runs rough then dies
I have a 85 coupe,the pumps are notorous for going out.Best bet is empty the whole tank.the pump .Is easy to pull its under the filler door.1 make sure its not your security system shutting off
your injectors .2 turn key in on poss and open gas door you should hear the motor.If not
disconnect batt and remove.be car e you dont lose the screen.once out dry off and hook up to any batt to check.there only 30 bucks but make sure you ground it out right and dont turn it on in a dry tank ,you will burn it out.
SOURCE: 1989 Bronco starts but dies after a couple of seconds
try checking the thermostat control senser. it caused my bronco to start for a second and then die. after a while it would finally start and run for a while then die driving down the road. i changed the thermostat control senser and it fixed all problems of dieing
