Question about NordicTrack Exercise & Fitness
Hi there I have a Nordictrack X7i incline trainer treadmill and just recently when I inserted the key the treadmill started to calibrate incline all the way up any stopped and doesn’t calibrate down I have tried to reset and unplug the power outlet but no improvement I continue to receive the same message as below image my concern is that the incline motor maybe damaged and need replacing any suggestions would be greatly appreciated
    Problem Solver:
  • 23 Answers
This seems abnormal. These machines seem to have an intermittent diagnostic that they run which includes (or simply consists of) raising and then lowering the incline or slope. If this process seems to hang or the machine never returns to "normal life", you may have to call your service number.
Posted on Feb 04, 2019
SOURCE:
  • 103 Answers
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ swflafitnessrepair@yahoo.com I will send this to you.
Posted on Nov 13, 2009
  • 34 Answers
SOURCE: Need to disassemble NordicTrack X7i trainer to
To get the manual go to iconservice.com and select the manuals link. You will be asked the model name or number. You can download a PDF file of the manual for free. Use the assembly instructions only backwards and you will be able to disassemble the machine.
Posted on Aug 10, 2010
e-Guru
  • 3917 Answers
SOURCE: i have a nordictrack x7i
Hi
It sounds as if you may have a button stuck on your console. Thus not allowing any other buttons to be pushed.
Remove the console from the treadmill and remove the backRemove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).Remove and replace all the connections on the console.
Reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced. Nordic track does not sell just the touchpads. Check ebay for your console it would be the cheapest. there should be a part number on the console in the inside or on the back of the plastic.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 15, 2011
ercupa190
  • 12223 Answers
SOURCE: treadmill nordictrack c 1900 motor doesn't run, belt doesn't turn
1) Lube the deck belt, in according with the instruction manual.
2) Lube the rollers bearing, with the i. manual
3) Test the input voltage motor, if there are the motor need repair
4) Test the output voltage board, for input voltage motor, if there are Not the board is faulty. God bless you
Posted on Jun 03, 2012
Incline not moving
Try to do the following hope it will solve the problem.
if its doesn't solve the problem then the the incline motor or the control panel is faulty.
HOW TO USE THE SETTINGS MODE T
he console features a settings mode that allows you to connect your incline trainer to your own wireless network and to log in to your iFit Live account. The settings mode also allows you to turn on and turn off the display demo mode. You may also be able to select the unit of measurement.
Select the settings mode.
Insert the key into the console . Next, select the start menu. Then, press the i button in the lower right corner of the screen to select the settings mode.
Select the maintenance mode.
Press the Maintenance button in the lower right corner of the screen to enter the maintenance mode.
Calibrate the incline system of the incline trainer.
Press the Calibrate Incline button. The incline trainer will automatically rise to the maximum incline level, lower to the minimum incline level and then return to the starting position. This will recalibrate the incline system. Press the Begin button to calibrate the incline system or the Cancel button to return to the maintenance mode. When the incline system is calibrated, press the Back button. IMPORTANT: Keep pets, feet, and other objects away from the incline trainer while the incline is calibrating. In an emergency, pull the key from the console to stop the incline calibration.
Restore factory defaults.
If necessary, press the Restore Defaults button to reset the firmware to the original factory firmware. This will erase all firmware updates that you have downloaded. Press the Begin button to restore the default firmware or the Cancel button to return to the maintenance mode. When the restoration is complete, the words PLEASE CYCLE POWER will appear in the grey box. Press the power switch into the off position. Wait for several seconds, and then press the power switch into the reset position. It may take a minute for the console to be ready for use.
Exit the maintenance mode.
To exit the maintenance mode, press the Back button repeatedly.
www.electro-medical.blogspot.com
Aug 31, 2015 | Nordic Track NordicTrack X7i Incline...
How to recalibrate 8600 incline trainer
To initiate the calibration routine, hold down the SPEED +
button and the SPEED - button simultaneously for three seconds. During the calibration routine, the INCLINE
TRAINER will automatically rise to the highest incline level and then return to the lowest incline level.
P.S. This is listed in your user manual in the "Troubleshooting" section if you don't have a user manual then you can get a pdf copy of it here
http://www.ereplacementparts.com/images/nordictrack/CTK59020.pdf
Aug 31, 2014 | Nordic Track NordicTrack Treadmill, A2550
Belt slips on high incline x7i
there are two belt adjustment bolts on the front if your machine. tighten both clockwise and make sure belt stays centered. do this with it running about 2mph
Aug 30, 2014 | Nordic Track Incline Trainer X7i...
Treadmill incline not working
The incline system may need to be calibrated. To initiate the calibration routine follow the steps below.
Step 1
Place the key into the machine. The key's slot is located on the bottom of the console, below the start and stop buttons.
Step 2
Press any of the incline buttons and then remove the key from the machine while the incline is changing. Pause for a few seconds and then put the key back into the slot.
Step 3
Wait as the treadmill automatically shifts to the highest possible incline and then descends to the lowest level. The treadmill should now be recalibrated.
May 30, 2014 | Nordic Track NordicTrack Treadmill, A2550
X7i will not power up
Hi.
Did you ever get to the bottom of this. I have the same problem. If you managed to fix it would you mind emailing me (mickclifford@hotmail.co.uk)
Jan 19, 2014 | Nordic Track Incline Trainer X7i...
How to troubleshoot Nordic Track X7i Console not turning on
In normal operation you put in the key and display should light up. Also there is a reset switch on the frame near the power chord which might be off. Below is link to the User Manual for NordicTrack x7i. I got that info on pg 16.
http://www.sportsmith.net/images/product_support%5CNordicTrack%5C248194%20-%20NORDICTRACK%20INCLN%20TRAINER%20X7I%20INTERA%20TREADMILL%5CNTL20909.3-299073.pdf
Jun 19, 2012 | Nordic Track Incline Trainer X7i...
I have a proform xp 580. when I turn it on,
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
After completing calibration of incline, press the Stop key and then remove the safety key.
Jun 12, 2010 | Proform XP 580 Trainer Treadmill
Nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
May 31, 2009 | Nordic Track Nordictrack Apex 4100i...
Calibration
My name is Mike; I am a service technician for ICON Health & Fitness, the manufacture of the machine mentioned. While my comments on your problem are geared generally to assist, you are welcome to call our customer service line at 18009993756 for specific instructions if needed.
The first thing to do with any incline problems with a treadmill is run “calibration.” Calibration restores all settings (including the incline sensor in this case) to the factory specs. Instructions to run calibration on your individual machine are taped on the underside of the motor hood. See your manual for removal of the hood. While each machine has specific calibration instructions most new models made by ICON will have similar steps to doing it.
To calibrate the incline you will need to press and hold the Stop and Speed + buttons while inserting the safety key or magnet. Then let go of the buttons. This will enter calibration level 1 which lists some machine information and a console memory test. Press the Stop button 1 time. This will enter level 2 of calibration. To calibrate the incline you can press either incline buttons (either the up or down arrows) and your incline should go all the way up and then all the way down. If this works then take the safety key or magnet out; turn the power off, and unplug it for several minutes. (On a side not you will want to turn the power off and unplug your machine whenever you’re not using it.)
If this does not fix the problem then it can be more complicated depending on the model and motor involved. It can range from the console not sending a signal to a loose wire or jammed motor. If this didn’t fix the problem then I would recommend calling in for further assistance.
Sincerely,
Mike
Customer Care
Mar 24, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
44 people viewed this question
Top NordicTrack Exercise & Fitness Experts
Craig Butler
Craig Butler
Ross Metcalfe
Ross Metcalfe
Kardoc
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
