Orange HD Digital Posted on Jan 12, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to solve e-1
It shows e-1
Clive
Level 3:
  • Master 4,362 Answers
  • Posted on Jan 12, 2019
Clive
Master
Level 3:
Answers
4362
Questions
0
Helped
1813520
Points
14613
When the Washing Machine is displaying E1 in the panel, it is indicating an error in the water supply. The appliance is not detecting that the unit is filling with water.28 Jun 2018
If the central heating or hot water system does not work a fault may have occurred on the boiler. An error code may be shown on the boiler. The codes are either two or three numbers, with the letter 'E' in front. If code E133 is displayed by 'E1' then '33' flashing, this means. The gas supply has been interrupted.
Problem solving and algorithms
11010101 = 1*2^0 + 0*2^1 + 1*2^2 + 0*2^3 + 1*2^4 + 0*2^5 + 1*2^6 + 1*2^7
from reverse order
2helpful
Solve the two sided inequality and show the solution on real line 7 < 1-2x &#8804; 10
7 < 1-2x ? 10
7helpful
7 < 1-2x ≤ 10
27helpful
4answers
Dual sim china mobile show on screen invalid sim
I HAVE A CHINA SET SIGMATEL S90 DUAL SIM ONLY SIM 1 IS WORKING FOR SIM 2 SHOWS AS INVALID SIM FROM FEW DAYS PLEASE SOLVE THIS PROBLEM
BABU
9035040544
I charged the Tungsten E and it doesn't show the charge
I didn't solve the problem. I just can't pay right now. I guess I'll keep asking until I get it solved. I purchased a battery last year I just need someone local ( Denver, Co 800014) to put it in for me. I just hope it will work..
thanks for your support
I truly appreciate what you all do.
Gwen
1helpful
Flashing L-1
When your copier scanner is locked.Then show L1
or sensor is dirty or scanner jam.
Solve: clean thoroughly then solve your problem.
21helpful
4answers
The 6306 L showing HAMMER VOLTAGE 1 ERROR WHAT SHOULD I DO
ERROR IS BECAUSE OF DRIVER IC FAULTY IN LOGIC CARD
PLZ CHANGE THE HAMMER DRIVER IC IN LOGIC CARD
For instance if I have a problem of 4x+1-x=2x-13+5. how do I enter it in my T E to find wha is X
This calculator does not have a Solve function or a solver. However this example of yours is very simple that you can do it by hand. If you do not mind I will show you how to solve it. Not everything needs a calculator.
You want to solve for x. OK
  1. Start by gathering similar terms 4x-x =3x; -13+5 =-8
  2. Rewrite your equation as 3x+1=2x-8
  3. Make the +1 change side while changing its sign
  4. 4x+1 -1 = 2x-8 -1 or 4x=2x-9
  5. Make +2x on the Right hand side go to the left hand side, changing its sign in the process 4x-2x=-9 or 2x=-9
  6. Divide both members by 2. This gives
  7. x=-9/2 or -4.5 if a decimal result is required.
Hope it helps.
1helpful
3answers
Names wont show up when contacts call
it may take awhile but you have to put a 1 infront of everyones numbers
i had the same problem but that solved it i didnt put a +1 just a one such as
12223334444
2answers
Net work adaper
1. What is the model number of you wireless adapter?
2. What is your Operating System? ( windows XP, 2000, etc )
3. What is the brand name or model number of your wireless access point?
4. Is it working before?
5. Are there other wireless computers working?
k24674
ADMIN Andrew
ADMIN Andrew
