Question about The Office Equipment & Supplies
What would cause the machine not to get 24v dc
    Genius:
  • 1,560 Answers
Power supply
Posted on Jan 12, 2019
3 Suggested Answers
  • 1514 Answers
SOURCE: how to operate a 24V dc 3 amp load from 24V dc 100
If you have a 24 V 100 amp source you can just plug in your 24 V 3 amp load and it will work. If the load was higher, near equal, or equal to the supply available that would be a problem but having a more amps available than are going to be needed is not a problem. The voltage available and drawn do need to be the same and in this case they are both 24V so you can work away.
Posted on Jan 11, 2011
  • 5189 Answers
SOURCE: I bought a pride wrangler mobility scooter. Did not move could hear a click coming from left motor. took right motor off and tore it down. It was all glazed over.
If two 24v batteries are the standard fitment it isn't likely it would be fitted with a 36v motor - unless some bright person fitted the wrong one...
I am not sure what you mean by "glazed over" unless it is the commutator you refer to? A commutator made from quality materials and fitted with brushes made from the correct grade of carbon or copper/carbon and being run at approx. the correct voltage is likely to become well polished and may become carbon black in colour but that is without detriment.
It is permissible to clean the commutator. I find spinning the armature in a drill and using a fine emery cloth is adequate.
Once reassembled the motor can be connected directly to 24 volts for testing.
Posted on Nov 06, 2016
Testimonial: "Thank you I will hook motor up to 24 volts and see if it runs. I assume i would use the wires marked = and -.which is forward and reverse."
Nov 06, 2016 | Pride Health & Beauty
Tip
ERROR codesCanon 7050
Canon 7050 E000 Heater (Reset by unplugging machine) E001 Heater triac, DC controller, AC driver (reset by unplugging) E005 Fuser cleaner belt at end. Replace. E010 Main motor, DC controller or DC driver board E011 Any motor ( main, scan, cleaner belt, duplex, toner, lens) DC driver, DC controller, duplex driver board. E020 Toner out signal has been sent for at least 3 minutes E050 Duplex E203 Scan motor, DC driver, DC controller E210 Lens home sensor not actuated or won't deactuate E240 Controller board E241 Controller board E242 Controller board E400 DC controller, Doc. Feeder board, 24V power supply E500 DC controller, sorter board, 24V power supply
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 4540
Canon 4540 E00 Low fuser temperature E001 High fuser temperature E010 Main motor clock pulse E011 Bind or load on main motor E020 No TF for 3 minutes E030 Copy counter E050 Duplex unit E201 Scan motor E203 Scan motor E210 Lens home E240 DC controller E241 DC controller E320 CCD E400 DC controller, 24V E500 DC controller, 24V E510 Finisher feed motor E520 Stacker motor E530 Guide plate shift motor E531 Stapler motor E620 DC controller, edit board
Canon ir 3300 error code e000803-0000
Similar to Description The 24V output from the composite main power supply PCB is absent for 1 sec or more Causes The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty. Remedy 1. Connectors Are the connectors J204 on the main power supply PCB and the connector J300 on the DC controller PCB connected securely? NO: Connect the connectors securely. 2. Main power supply PCB Is 24 V supplied by the main power supply PCB (J204) to the DC controller PCB (J300)? (J204-5 <-> J300-5: OVU3, J204-6 <-> J300-6: OVU3, J204-7 <-> J300-7: 24VU3, J204-8 <-> J300-8: 24VU3) NO: Replace the main power supply PCB. YES: Replace the DC controller PCB.
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
Aug 21, 2012 | Canon Ir 3300 Black & White Copier
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 | Vacuums
Tip
ERROR codes Canon 4035
Canon 4035 E000 Low fuser temperature E001 High fuser temperature E010 Main motor clock pulse E011 Bind or load on main motor E020 No TF for 3 minutes E030 Copy counter E050 Duplex unit E201 Scan motor E203 Scan motor E210 Lens home E240 DC controller E241 DC controller E320 CCD E400 DC controller, 24V E500 DC controller, 24V E510 Finisher feed motor E520 Stacker motor E530 Guide plate shift motor E531 Stapler motor E620 DC controller, edit board
on Jan 18, 2010 | Office Equipment & Supplies
I check do not power DC24v input inverter how to fit it?
first you have to check 24v dc on power supply board.if power board 24v ok then there is one ic link on inverter board.check is this ic link ok or not if its open then replaaced it.check one end of ic link 24v dc come?
Oct 16, 2010 | Emerson LC320EM8 32 in. LCD TV
Canon clc 1110 gives E 803 0000 error. What could be the solution ?
the 24v is faulty
the dc power cut relay is faulty
the dc pcb is faulty the dc driver pcb faulty
during copy operation the cpu does not detect 24v out put for 5 seconds when the transfer unit lever switch,front cover switch,and delivery cover switch is closed
May 17, 2009 | Canon CLC 1110 Copier
Error code E000803-000
that mean low power or The 24V output from the composite main power supply PCB is absent for 1 sec or more.
Main cause The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty.
Making Corrections
1. Connectors
PCB (J300)?
Feb 05, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
22 people viewed this question
Top The Office Equipment & Supplies Experts
Scott Yeoman
vince
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
