Question about The Office Equipment & Supplies
Nashuatec DSM 615 aficio have to add toner manualy. how can i access the add toner motor in the machine and whats the simulation for forced toner?
3 Suggested Answers
  • 17804 Answers
SOURCE: why is it that the toner in my photocopied documents does not dry? ....machine model Nashuatec Aficio Dsm415pf
The fuser is bad. There is a heater in the unit that cases the toner to bind to the paper. It is called the fuser. THEY ARE NOT CHEAP
Posted on Jun 13, 2014
  • 5690 Answers
SOURCE: manual guide for aficio copier dsm 620
Most makers have a PDF file Manual by going to the makers site and navigating to the list of Manuals. Then you can either print your own once it is fixed or keep getting it online. For a few pages you can get copies for a modest fee or free at Libraries.
Posted on Jan 26, 2015
Manual guide for aficio copier dsm 620
Jan 26, 2015 | Office Equipment & Supplies
How to increase toner level
You cannot do that. What is wrong with the machine's operation?
Aug 27, 2014 | Gestetner Dsm 615 616 618 620 716 721...
Why is it that the toner in my photocopied documents does not dry? ....machine model Nashuatec Aficio Dsm415pf
Jun 13, 2014 | Office Equipment & Supplies
Nashuatec dsm 615
State exactly what equipment, programs, and/or devices are relative to the dark and lined condition? With out that information we cannot assit you with the problem at hand.
Dec 31, 2013 | Computers & Internet
Help with error code SC547-01
sc 547 mean fixing unit error ,you can reset by simply getting into simulation mode and then switch off an the machine ,getting into the simulation mode is simply by pressing 107 and press and hold c ,
Jun 19, 2013 | Ricoh Aficio 450 Copier
Aficio MP161 Toner bottle doesn't turn to add toner.
How many copies on that machine? The photoconductor unit on that model only goes 45,000 copies. If the machine wont tone up and the pcu is old i would replace it and calibrate to see if the problem goes away. The pcu is cheap for that model. Start there would be my advice.
Jul 23, 2012 | Ricoh Aficio MP 161 Black and White Copier
Add toner ricoh aficio 2045
Toner supply is controlled with readings from TD sensor on the developing unit and the I.D sensor above the drum by default.
These are low cost parts and easy to change.
(The TD sensor on this model have been known to fluctuate back and forth by a fair margin so is a good place to start).
You could also try stripping down and cleaning out the toner hopper.
Check the four mylars are present and the grabber is opening wide enough to grab the toner bottle nozzle successfully.
Check the toner hopper exit slider is opening fully when the PCU is inserted.
I had one of these 'add toner' faults today and it was the toner hopper all clogged up inside.
The side bit where the toner drops down had hardened clumps of toner stuck around the side entrance mylar and the exit hole.
Check also the toner motor. I have seen these fail. Run simulation output check for toner motor. I would remove the toner supply unit and hold the motor when you run this simulation. Sometimes the motor turns but does not have enough torgue to turn the toner supply unit.
Mar 05, 2010 | Ricoh Aficio 2035 Copier
Code 326
Replace the motor ( AX050117) I have seen that if you have a false add toner the part A2327263 has had the plastic tabs come off in the toner assy and the tabs block the opening to the developer assy. -Carl
Jun 22, 2009 | Ricoh Aficio 450 Copier
21 people viewed this question
Top The Office Equipment & Supplies Experts
Scott Yeoman
vince
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
