You did not mention for which application you want to set portforwarding for. So go here, and look up the right application for you.
You can also look around and see how it is done in general. The most important values are the port numbers and the protocol (TCP/IP and/or UDP) you want to forward to.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
SOURCE: port forwarding? 2wire 2701hg-T
access your gateway homepage by opening your internet browser and typing this on the address bar: 192.168.1.254/management. then key in your system password and click on Settings under Firewall. there's option#2 (allow individual applications), click on "Add a new-user defined application", input the data and click submit another way is to enable DMZ plus mode. that option would actually make all the ports open. use this if option#2 is not working. after making the above changes refresh your router, just unplug then replug it from the power.
SOURCE: Port forwarding on dlink adsl2 router
Step 1. Before you open ports in your router, set the computer (or the device) which requires
ports to be opened for, with a static IP address. You can choose any IP address from the
range of addresses you are using on your local network, as soon as it is not used by any other
device. The default range is from 10.1.1.2 to 10.1.1.254. In our example we are using
10.1.1.99.
Windows XP: Control Panel > Network Connections > Local Area Connection > Properties >
Internet protocol TCP/IP > Properties
Windows Vista: Control Panel > Network and Internet > [Network and Sharing Centre] > View
Network Status and Tasks > View Status > Properties > Internet Protocol v4 > Properties
Select the “Use the following IP address” option:
IP address: 10.1.1.99
Subnet mask: 255.0.0.0
Default Gateway: 10.1.1.1 (your router’s address)
DNS: 10.1.1.1 and 61.88.88.88 (or whichever your provider is using)
Now open the necessary ports in your router and redirect the traffic to the 10.1.1.99 address.
Here are the steps:
How to open ports in your router Page 2 of 6
Step 2. Open your web browser and enter the IP address of the router (http://10.1.1.1). Enter
user name and password (default username “admin” and password is “admin”).
Step 3. Click on Advanced at the top and then click on LAN Clients.
How to open ports in your router Page 3 of 6
Step 4. You will need to add a LAN Client (the address of your computer or a device) into the
router before you can open any ports. Type in the IP address of the Computer/Device (the
one you assigned in Step 1). You can specify the name of this workstation under Host Name
(optional). Click Add and then Apply.
Step 5. Go to Advanced > Virtual Server (Port Forwarding). There is a list of pre-set ports in
the router which you can choose from.
How to open ports in your router Page 4 of 6
Step 5a. If your specific application is not listed there, you can add the necessary ports
yourself. Select the “User” Category and click on Add button below.
Step 5b. Enter a name for this entry under Rule Name. Then select the necessary protocol. If
there is a range of ports to open, specify the starting port under Port Start and the ending port
under Port End. If you need to open just one port, specify this port number in all fields
including the Port Map. Click Apply.
How to open ports in your router Page 5 of 6
Step 6. Go back to Advanced > Virtual Server. Under LAN IP select your LAN Client (which
you added in Step 4). Select the Category and the desired Rule or select “User” Category
and you should see the rule which you have created in Step 5b. Select it and then click on
Add > to move it into the Applied Rules section. Click Apply.
Step 7. To save the new settings into the router's memory go to Tools > System. Click on
Save and Reboot button. The router will save the settings and restart.
SOURCE: How do I port forward
Use this link:
http://portforward.com/english/routers/port_forwarding/2wire/2700HG-E/2700HG-Eindex.htm
Then scroll down to the game you want to port-forward, click on that game. Follow all the instructions. Then do a Port checker test:
http://portforward.com/help/portcheck.htm
Now enjoy your game!
Testimonial: "it worked, Thanks very much"
need to connect to stan alone dvr using pcviewer d6 series
port 80 forwarded but i get time out no stream error message -3
