if you need support for your Dell inspiron 570, Blue Screen of *****, Fix Blue Screen Errors, Blue Screen Error in Computer, Blue Screen Error in Laptop, Dell Technical support Number, Dell computer support, Dell laptop support Number 1-800-204-4427 (toll-free) and more... http://www.delltechnicalsupportphonenumbers.com/blue-screen-of-*****
Acer Aspire 5517 shows BLUE light when fully charged.
Start it and check battery indicator (tray item) will probably say
plugged in fully charged (with adapter plugged in)
The majority of laptops will display a solid green, blue or
purple battery light to indicate that the battery is fully charged. Most
manufacturers indicate that a laptop is in the process of charging by
displaying a solid or blinking green, orange, blue or purple light. If
your battery indicator light is green, blue or purple, the battery is
probably functional, regardless of whether the light is blinking. If the
light is solid orange, the laptop is probably in the process of
charging.
Battery Error Coneventions
Many battery manufacturers use rapidly blinking lights to
indicate that a battery's charge level is low. In general, a laptop will
rapidly blink orange or red when its charge drops below a certain level
until the computer is plugged into a power outlet and charged. If your
laptop's battery indicator continues to blink rapidly in orange or red
or if it remains red even when it is plugged into the charger, it
indicates a problem with your battery or the charger.
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
try connecting ac adapter alone without the laptop, check if ac adapter light will stay green or blue. try another power outlet using the ac adapter alone without the laptop check if the ac adapter light will stay as green or blue. if all fails replace ac adapter.
if ac adapter stays green or blue try connecting to the laptop without the batt, check if the ac adapter light will stay on, if yes then try connecting ac adapter to laptop with the batt plugin check if the light stays green. if not update the BIOS. if fails replace motherboard.
at battery mode....you cannot turn on the blue lights because the battery is low at that time....due to that it will not turn on the blue at that time....if you want to turn on blue lights during battery mode when you use your laptop in battery mode then the only way is to charge your laptop when your laptop is in battery mode.....there is no other way
