Question about Karcher Garden
Hi Geoff carried out search for a service maintenance manual for a Karcher HDS 555 C hot pressure washer. You say on your search in Fixya you have a copy. can I buy a copy off you, is it PDF ?
The model is Karcher HDS 555 C year 1997 036442 is on the tag. your help will be much appreciated. Does it also include wiring diagram also
  • Glenn Young
    Glenn Young Jan 12, 2019
    Thanks Matt for quick reply no luck on that site my unit not listed. Thanks for reply.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,445 Answers
Try here
https://www.manualslib.com/brand/karcher/pressure-washer.html
Posted on Jan 12, 2019
3 Suggested Answers
SOURCE:
  • 32 Answers
SOURCE: hi,karcher hds hot pressure washer now pressure
what you need to do is, take the screw fitting which goes to the water tank off, then the one that goes from the water tank to the pump head .
then put the one that was in the first place going to the water tank on to the pump and force feed with water.
see if you can see water leaking from any where seals hose.
try running the machine to check the pressure.
if water leaking from pump head you need seals.
Posted on Jul 04, 2009
  • 88 Answers
SOURCE: I am looking for a workshop manual for karcher hds
hi could you post your email address and i can email you a full pdf file, also on the chassis of the machine there will be a silver sticker could do with all the numbers to find which modle it is regards
Posted on Jan 20, 2010
My karcher isn't giving me hot water why? It's a hds 601c
Morning Chris Taylor,
You have an igniter/burner coil inside your system that has to be
functioning properly to have good combustion going inside the coils of your heater unit (very bottom).
I tried to pull the documents to see if yours was kerosene powered (like mine: not a Karcher)... but could NOT pull your HDS 601C up on the company site (Karcher.com, sorry... It's me & my new PC).
Poor water = de-lime water coil procedure
Cool water = No combustion, check kerosene, oil (burner fuel)... filter... (etc.) and check your spark!
If your air supply is insufficient to support great combustion your ignitor & fuel nozzles can get heavily built up in soot. My manual says to clean it with detergent & water... I have only ever used Berryman choke & throttle body cleaner.
All the precautions... don't hurt yourself!!
Hope this helps...
KARCHER HDS 601c ECO STEAM CLEANER BOILER HEATING COIL ELEMENT HEATER...
Operating manuals
http://www.ultimatewasher.com/download/hot-water-manual.pdf
May 01, 2016 | Karcher Garden
I would like a karcher instruction manual for a HDS650 pressure washer
I believe the HDS sends spark to the ignitor any time the machine is on ( hot or cold) You should hear the crackle of the ignitor in the burner area. Perhaps the ignitor rods are not properly aligned. Perhaps your ignitor coil is bad. There are several safety switches and the thermostat that would keep the burner from firing if they are bad. There is a pressure switch that turns on and off the motor for hot or cold operation. That is apparently working. I think there is a flow switch that turns off the burner. The thermostat might not be opening and closing contacts and that will keep the burner from working. I believe there is a high temperature safety switch as well.
Jul 15, 2014 | Garden
Karcher HDS 7/10-4M has the oil light giving 4 flashes, what does this indicate as the fault.
Ive got a brand new HDS 10/20 and its crapped out on me already, water line filters were blocked, cleaned them out and now it splutters after 2mins of pressure washing, oil light flashing x3, nothing in any of their **** manuals to assist, any ideas before i set it on fire?
Jan 19, 2013 | Karcher Garden
I am looking for a workshop manual for karcher hds 555 ci hot pressure washer.or access to where i can download one. any assistance is greatly appreciated
Jan 19, 2010 | Karcher PSI Electric Pressure Washer
Hi,karcher hds hot pressure washer now pressure when you pull trigger and pulses.
Mar 21, 2009 | Karcher Garden
KARCHER HDS 1000 de
Hi Jim,i have the same unit to,can you tell me are you connecting to mains water via the small black header tank at the back next to the boiler or is it connected straight to the pump head inlet?
Theres more than one reason i'll just start with this one 1st.
chris
Aug 08, 2008 | Karcher 2500 PSI Pressure Washer
Karcher HDS 750 HOT HIGH PRESSURE WASHER
G-day Mate.
Did you check if the igniters? they may be cloged up with ****. Unscrew the Sight glass on top of the boiler and run the machine (in cold or hot mode, doesn't matter, as the igniters are running all the time) and see if there are working, you should take them out anyway and give them a wipe with a rag as general maintenance item, and when you put them back in there should be about 5mm gap between them.
Less common reasons for the boiler to not work
- Faulty fuel solenoid valve, (You should hear a click sound about 5 - 10 seconds after you pull the trigger)
- Dirty fuel filter,
Take a look at those simple things and let me know if its any of these.
I have a Karcher HDS 750 1989 Year model
This machine just keeps going, it's had a fairly tough life but it has stood up to it all,
i hadent spent anything on it until about 6 months ago when i purchased a new fuel pump for it as the old was wasn't pushing 170PSI to the Disiel injector it had slowly droped 70psi, and it doesn't create a hotter burn in the boiler, but still very good for a 19yr old pump,
other than that thats all it's needed, it's still going strong to date
Very robust machine.
my e-mail is cgodfx@internode.on.net
Cheers Matt.
Apr 07, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
29 people viewed this question
Top Karcher Garden Experts
John Trevino
Ian Summerfield
Ian Summerfield
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
