SOURCE: machine wont fill
If you hear a valve or relay opening and closing (a small click), then check both of your hoses for signs of internal collapse and while they are off, clean the screens you may find in both ends.
If you see nothing amiss, open both of your feed faucets to make sure it is not a problem with the water supply itself.
SOURCE: ZANUSSI FRONT LOADER
fixed the problem by threating to report the spanish shop for racism next day tech/man arrived done job
SOURCE: fisher and paykel smart drive
Hi, just read your posting.Now the possible fault could be your display board.When you turn the power on to the machine from the power point do all the lights come on and you hear an audio beep beep , then the lights go out ?If that happens, then do you push start and can not select anything else like water temp or load size?Or do a series of lights light up and it beeps indicating a fault code after you have pushed the power button? Please reply and I can guide you throe step by step the process needed to fix this problem.
SOURCE: My hand-me down top loader
Hello &
Welcome to FixYa The beep can
either be due to a bad control board assembly or the lid switch however, please
get back to me if there are any other error codes appearing. If the control
board is fine then it can be a bad motor. Please get back to me if you have any
other questions. Kevin
SOURCE: Candy Grand 1600 AAA class
Hello
& Welcome to FixYa You
can start with cleaning the drain filter pump assembly located inside the front
bottom panel of the washer. After it's cleaned and the problem is back then
replacing the control board is recommended repair. Please get back to me if you
have any other questions. Kevin
