SOURCE: blood pressure monitor problem
The two numbers that measure your blood pressure are written like a fraction: one number on top and one on the bottom. The top number in a blood pressure reading refers to the systolic pressure. It measures the pressure inside your blood vessels at the moment your heart beats. The bottom number represents your diastolic pressure. It measures the pressure in your blood vessels when your heart is resting between heartbeats. A good blood pressure for most people will be under 120/80, as most people with blood pressure problems have high blood pressure. However, extreme low blood pressure can also be a serious health concern.
SOURCE: blood pressure measurements support
There are two positions for taking your blood pressure measurements: Sitting down - Place your elbow on a table. Using a flat object as support, position your wrist at heart level. Your blood pressure measurement will be too low if you hold your hand too high, or too high if you hold your hand too low. Lying down - Lie on your back. Rest your wrist on a support or cushion with the palm side facing up, position your wrist at heart level. On both of the positions you need to open and relax your hand with the palm facing up (closing your hand will cause inaccurate readings). Do not bend your wrist inward, as bending your wrist will cause inaccurate readings. If possible, empty your bladder before measuring your blood pressure, for a more accurate reading.
SOURCE: blood pressure Question
Measuring your own blood pressure is an important way of monitoring your health. High blood pressure is a major health problem, which can be treated effectively once detected. Measuring your blood pressure between doctor visits on a regular basis in the comfort of your home, and keeping a record of the measurements, will help you to monitor any significant changes in your blood pressure. You should also keep an accurate record of your blood pressure, to help your doctor diagnose and possibly prevent any health problems in the future.
SOURCE: Why wont my Omron Blood Pressure Monitor work?
I contacted the manufacturer here is the response with information to contact them yourself if this does not help.
I am sorry to hear that you are having this issue with your readings and would be happy to assist you in determining where the problem lies.
Initially, I would like to provide you with some basic user information on factors that could impact the quality of your readings enough to cause the E error message you have been receiving. I will follow that with some critical steps that you must take in order to obtain a reading on your Omron unit.
User technique is important for reliable measurement results. Listed below are the common causes why you may get an erroneous reading:
Cuff Size - Measure the circumference of your wrist. If the incorrect cuff is used, you may get an inaccurate reading or error messages, if not at the first reading, then after a short period of use because the cuff bladder will be damaged. To determine your wrist size, measure your wrist approximately ½” above your wrist bone using a cloth tape measure. Wrap the tape measure evenly around your wrist. Do not pull the tape tight.
*The cuff that came with your unit is appropriate for wrist circumferences of 5 ¼ to 8 ½ inches. If your wrist circumference is not within that range, your readings will be inaccurate or you may receive error messages.
Cuff Application - Make sure you are wrapping the cuff around your wrist in the correct position. The cuff should be wrapped snugly around your wrist. If your wrist monitor can be used on either the left or right wrist, make sure you have set the monitor to the wrist you are using.
*If the cuff is wrapped too tightly or too loosely, your readings will be inaccurate or you could receive an error message.
Before Taking a Measurement - Avoid eating, drinking alcohol, smoking, exercising, and bathing for 30 minutes and rest for 15 before starting the measurement. Avoid taking a measurement during stressful times. Take the measurement in a quiet place.
Body Position - Sit in a chair with your feet flat on the floor. If you do not have your wrist at heart level, your reading will be affected. Holding your arms or shoulders tensely may affect the reading. Remain quiet while taking the measurement.
The E error message is telling us that the unit is recognizing some type of interference while taking the reading. This could be as simple as speaking or moving, having a computer, cell phone or medic alert device too close to the phone, a loud television/radio in the same room or more complicated, such as a rapid or weak arterial pulse.
Reading Timing - Because Omron units read your blood pressure by 'listening' to the blood as it vibrates through the artery, the artery must be fully opened for an accurate reading. It is critical to wait a full 5-10 minutes between readings to allow the brachial artery to 'bounce back' from the initial constriction.
Refer to the Instruction Manual provided with the unit for the complete operating instructions.
If after reviewing the information above your unit is still not functioning properly, in order to best serve you, please call our Consumer Support team, toll-free at 800-634-4350. Our trained representatives are available Monday through Friday, 830a to 430p CST to assist you over the phone and try to resolve your issue without sending your unit in for repair. If repair is necessary, they can set up your file to start the process or provide valuable options to your particular situation.
Please have the following information available in order to expedite your call:
1. Model number (from the front of the unit)
2. Serial number (from the sticker on the side of the unit)
3. Proof of purchase information - from the receipt or online verification.
4. The wrist circumferences of all users of your unit.
They will be happy to assist you with your options regarding service.
We appreciate your interest in Omron products and want to ensure your satisfaction.
Please let me know if I may be of further assistance and have a wonderful day!
Jon McGillicuddy
Customer Service Representative
Consumer Support
Omron Healthcare, Inc.
SOURCE: solve GSM CMS Errors......
I can't send msg from smslib.Pls help me.
I get below message(cms error 500)
Example: Send message from a serial gsm modem.
SMSLib: A Java API library for sending and receiving SMS via a GSM modem or other supported gateways.
This software is distributed under the terms of the Apache v2.0 License.
Web Site: http://smslib.org
Version: 3.4.4
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [jar:file:/C:/Program%20Files/Java/jre1.6.0/lib/ext/slf4j-jdk14-1.5.10.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [jar:file:/C:/Program%20Files/Java/jre1.6.0/lib/ext/slf4j-log4j12-1.5.10.jar!/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
Jan 25, 2010 4:17:27 PM org.smslib.helper.Logger logInfo
INFO: SMSLib: A Java API library for sending and receiving SMS via a GSM modem or other supported gateways.
INFO: Version: 3.4.4
INFO: JRE Version: 1.6.0
INFO: JRE Impl Version: 1.6.0-b105
INFO: O/S: Windows XP / x86 / 5.1
Jan 25, 2010 4:17:28 PM org.smslib.helper.Logger logInfo
INFO: GTW: modem.com5: Starting gateway, using Generic AT Handler.
INFO: GTW: modem.com5: Opening: COM5 @9600
Jan 25, 2010 4:17:35 PM org.smslib.helper.Logger logInfo
INFO: GTW: modem.com5: GSM: Registered to foreign network (roaming).
INFO: GTW: modem.com5: MEM: Storage Locations Found: MESM
INFO: CNMI: No best match, returning: 1
INFO: GTW: modem.com5: Gateway started.
Modem Information:
Manufacturer: Sony Ericsson
Model: AAB-1022011-BV
Serial No: 359672005252294
SIM IMSI: ** MASKED **
Signal Level: 38%
Battery Level: 88%
Jan 25, 2010 4:17:47 PM org.smslib.helper.Logger logWarn
WARNING: GTW: modem.com5: CMS Error 500: Retrying...
Jan 25, 2010 4:18:11 PM org.smslib.helper.Logger logWarn
<< OutboundMessage >>
Gateway Id: *
Message Id: 0
Encoding: 7-bit
Date: Mon Jan 25 16:17:36 MMT 2010
SMSC Ref No: null
Recipient: +095067696
Dispatch Date: null
Message Status: FAILED
Message error: NO_ERROR
Validity Period (Hours): -1
Status Report: true
Source / Destination Ports: -1 / -1
Flash SMS: false
Text: Hello From SMSLib
PDU data: C8329BFD0619E5EF3668DA9C32D362
Now Sleeping - Hit <enter> to terminate.
Jan 25, 2010 4:18:37 PM org.smslib.helper.Logger logError
SEVERE: GTW: modem.com5: CMS Error 500: Quit retrying, message lost...
Jan 25, 2010 4:19:11 PM org.smslib.helper.Logger logInfo
INFO: GTW: modem.com5: Stopping gateway...
INFO: GTW: modem.com5: Closing: COM5 @9600
INFO: GTW: modem.com5: Gateway stopped.
Thz for any help.
I hope this helps.
If this Answer goes some way towards helping to resolve
your Query, Problem or Fault, please take the time to Rate it.
Doing so helps Solution
Providers, like me, better understand the needs and the point of view of
Askers, like you, and guides us in exploring the best ways to provide the most
comprehensive, useful and high quality Responses and Solutions we can.
If you need further
help, please do not hesitate to post another Question or add a Comment to this
Question.
Thanks for using FixYa.
