SOURCE: belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
SOURCE: Baumatic B501SS Built In Stainless steel electric single oven
If the fan is working in the main oven and there is no heat, then it will be a faulty element.
Remove the cover at rear of oven
and you will see the round element. remove it and replace with new one.
Plz rate my solution .
Thanks.
SOURCE: Oven door falls open and will not close tight on
The hinges and receivers would need to be replaced on this. The hinges are part number 71003351 you need 2, they go inside the door, so the door would need disassembled.
The receivers (hinge receptacles)are part number 71002206 you need 2 also, these go on the side of the oven. You will need to pull the oven out a few inches to gain access to these
SOURCE: single wall oven. error code: c75 comm error. door
You controller is bad. C75 is "Redundant strobes on logic board are not the same."
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
SOURCE: chef double oven, top oven
Hi As it is a 19yrs old oven so the issue is either with the
hinges or the door latch lock assembly has gone bad and should be replaced. If
the door hinges appear fine then you have to replace the lock assembly. Hope
this helps...please post back for further assistance. Daniel
