Question about Blade Saws
Motor overheatin with out the cutting blade intack.Question;is it the capassoter or are the motor start burning.
  • 33 Answers
SOURCE: motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Posted on May 02, 2009
SRF518
  • 232 Answers
SOURCE: Blade stops going once it hits the metal to be cut.
inside the motor/arbor section of the saw, there is a helical gear and worm drive on the motor. the front of the motor is supported by a bearing in the aluminum arbor section. sounds like most of the bearing balls are disintegrated and the worm disengages when a load is put on it but spins when there is no load. I would check and replace the front bearing.
Posted on Oct 24, 2009
Testimonial: "I haven't dismantled the saw yet but at least the problem has been narrowed down. Thanks for the hint."
  • 464 Answers
SOURCE: seized tub - Maytag pavt244aww washer
you may have a seized up pulley on your pump. this will burn the belt. also check the pulley on the end of the motor.
Posted on Oct 27, 2009
brewerstool
  • 141 Answers
SOURCE: I was cutting a piece of timber when the
There is no reset button on your motor. Sounds like you have a fried motor. You should be able to easily remove the motor for inspection. Remove the 4 screws holding the motor onto the frame. Be sure to remove your brushes before taking the motor off. After removing the motor, you should be able to take the armature out easily. If not, you know that the armature and field are swollen from heat and the entire motor assembly should be replaced. May not be cost effective at this point. If you can remove the armature check for damage to the field and armature. Look for burn marks and comm bar damage. There may be a short in the field or armature and for that you need a special tester. If you have any questions please post.
Posted on Nov 04, 2009
Testimonial: "Thsi is really helpful,as i was just about to send the saw off to be repaired. I might now buy a new one"
al_kupchella
  • 843 Answers
SOURCE: 7 1/4 B&D saw - blade stalls but motor continues to run
There should be a special washer between the bolt (that holds the blade on) and the blade. If the arbor has a flat side on it, then the washer should have a matching hole so that the washer cannot turn independently of the arbor. Or, some saws use a spring washer which is cupped and becomes flattened against the blade as the bolt is tightened. If you have the first type of washer, perhaps the bolt is just not tight enough. If you have the second type of washer, perhaps the washer is backwards. If you have neither type of washer, you need one.
Posted on Jul 28, 2010
My saw smoke whencut n wood
With the saw unplugged, look at the blade.
1) Is the blade black and charred?
2) Smell the vents at the side of the motor, does it smell burned?
Changing to a sharp blade will fix problem #1. Push the blade into the cut slower, keep it straight (no cutting curves), and maybe set the blade to a shallow cut and make several passes.
If the motor stinks, check to see if there are violent sparks coming from the motor when running, if so that's an indication you should get another saw. Done!
Oct 19, 2017 | Saws
I have a QEP 7" tile saw. When I plug it in and press the switch, it hums-blade does not spin. (Note: not ready to cut tile yet, so no water in the bottom) Does anyone have any ideas on what's wrong?
Sounds like a shorted motor,or a dead spot on the armature. Try rotating the blade manually with no power first, then plug it in to see if it starts up. Don't let it hum for more than a second at a time, or it's sure to burn up the motor our trip the breaker.
Feb 12, 2016 | Qep Saws
My saw stops rotating during cutting
does the motor stop? If not the gears are worn between armature and spindle. If it does stop you could be applying too much pressure trying to cut with a blunt blade or there is an armature fault.
Apr 24, 2014 | Skil 10-in 15-Amp Compound Miter Saw...
Dewalt dw708 manual
Unplug the saw, Check the blade to see if it will turn by hand, if it does, check for any debris under the blade area. If everything is free'ed up, then check that all switches and safetys are engaged all the way and not halfway . Then plug the saw back in and try it. If it still doesn't start. then use a multi-meter and check for power at the motor. If there is power there, then you either have worn out brushes or a burned out motor.
Jan 20, 2014 | Saws
D24000 wet tile saw smells of burning. What could this be?
mmm.. motor problem,armature or field coil burned or bearing burn motor housing
Jun 03, 2012 | Dewalt D24000S Heavy-Duty 10-inch Wet Tile...
Motor buzzes, fan does not move, blade does not move, blade is clear of obstruction
Removing blade will not do it - there has to be an obstruction in the drive mechanism that prevents it from turning. Leave off till fixed lest you risk burning out the motor completely. Turn on AFTER you can turn the blade freely.
Sep 03, 2017 | Remington 3-Amp 17" Extended Reach...
Motor dies when i lower the blades
first you need to check under deck to make sure nothing is caught in blades like a stick or plastic wrapped around them
May 16, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I was cutting a piece of timber when the "off cut" got jammed and the blade got wedged.I stopped straight away but there was a faint smell of burning and the saw has not worked since. Is there a cut off...
Oct 31, 2009 | Hitachi C10FCE2 10" Compound Miter Saw
Oct 24, 2009 | Ryobi Saws
Saws Logo
23 people viewed this question
Top Blade Saws Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Blade Saw Expert? Answer questions, earn points and help others
