SOURCE: saeco milk island - no froth
Molly -- re: position of grey plug. I don't think this makes any difference at all. The key issue is to make sure those two slots are clear of debris or moisture. One month on and I have continued to achieve thick frothy milk purely from rinsing the milk island parts under a running tap, leaving them to dry, and then giving a short sharp blow to the two slots in the valve before reassembling.
Good luck
Guest with Solution 2
SOURCE: Steam not frothing milk
Have you decalcify the machine, the boiler does not heat up if there is calcium in it.
SOURCE: Mr Coffee Maker FTX25 - coffee tastes bad
Try running a 1/3 white vinigar -2/3 water mix into the brewer, let it brew, then run several pots of clear water through it. This should clean up any bad taste.
SOURCE: Plastic Smell & Taste
Just because its made of plastic doesn't mean it should taste like plastic! The engineers made a mistake in design! Get your money back and don't risk taking in carcinogens!
SOURCE: milk not frothing
Remove the black plastic outer sleeve of the Frothing Wand (some models have a metal outer sleeve). If done correctly, the “sleeve” has been removed, but the inner wand with red or black washer, is still connected to the machine.
2) The part of the sleeve assembly that you have removed is comprised of 2 pieces, the frothing sleeve and the center piece. The center piece can be seen if you look into the top of the wand.
3) Using a pencil (eraser end), or similar shaped object, push down on the center piece until an audible “click” is heard. The “click” means that the centerpiece is back into the proper position. When in the proper position, the center piece visibly sticks out the bottom of the sleeve about ¼-inch. It looks like a bird beak.
4) Now put the sleeve back on the machine and your machine should be ready to froth again.
As for the milk island, translaltion from the italian solution using google and drying all the parts works
