Question about Grundig Televison & Video
My grundig 40 vle 6142 c tv dims after power on
    New Friend:
  • 39 Answers
Problem on switch digital, maybe on diode or integrated circuit
Posted on Jan 12, 2019
2 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: I have Grundig 32 VLE 6520 BH and When I find programs automaticly it finds it and it is all ok until I turn off the tv. When I turn on again the programs are gone and i have to do it all over again.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Apr 23, 2016
Apr 23, 2016 | Grundig Televison & Video
Grundig t55-549 forgot pin code
Try 0345 563 582 515 098 584 219 104 233 223 065 471
Grundig
FT70-700 822DOOFA MW82- 500IRDT ST63725 ST63755 TF55-302 GT210S. MW822699 CVC2030ST ST70-875
563
Grundig
T70-1021, T70-1022
065
Grundig
MW82701 ST55/730 MW70/2700
582
Grundig
GT1401
515
Grundig
T55-1120 T55-1020 WF703020
471
Grundig
32WF100 W82-2030
584
Apr 21, 2014 | Televison & Video
Grundig tv factory reset
TV Grunding 49 VLE 6523 BL reset PIN
Sep 01, 2013 | Grundig GU19WDVDPCX 19 in. LCD TV
Olevia vle-42fdvldrb
The information you provide does not allow to automatically nail the board that is causing the problem.
Over time information may build up , enough to allow statistical probability of pointing out the source based on this description alone, but as of right now you can't be certain.
What I would do is disconnect the backlight portion of the TV from the power board and see if the problem continues.
Then I'd take the power board, signal it individually as illustrated in many articles around the net and see if it comes on and stays on.
Another approach would be to just start repalcing the suspects.
Usually it goes in order of "cheapest to try first in order of likely troublemakers" and that may vary for different TVs and at different times.
The power board is always going to be a suspect when an electronic device does not want to come up and as such you may consider the following:
http://www.coppelltvrepair.com/p/421/olevia-vle-42fdvldrb-power-board-tested-working-credit-for-old-dud
If you happen to go ahead with it (and even if not) please be so kind to update your findings in this thread so that others after you may use your experience.
It takes so little to help each other out!
Jul 15, 2012 | Olevia LT42HVi 42 in. LCD Television
Grundig Cinemo TV will not start
The power supply could be failing.
Jun 02, 2017 | Grundig Televison & Video
Bravia hdtv lcd momentary dim
It sounds like the power supply may be going. The back lights on a flat screen works the same as a flourescent light fixture. Flourescent lights have a ballast that powers on the bulbs. Flat screen tv's have capacitors on the power supply that when they charge power on the back lights of the tv. When you see the tv go dim it is actually the back lights that are dimming. This is usually from a faulty capacitor on the power supply not charging to its full potential. If you can open the tv and find the power supply look for any capacitors that are bugling at the top. These are most likely the culprits. A good cap tester is always handy to have although they are expensive ($100) it usually isn't cost effective to have it around just for rare occassions like this. You can remove the caps and take them to Radio Shack and they should be more than glad to test them for you. Before you do any of this though, look in your owners manual and see if there is a setting to where the tv does not use as much power. Maybe something like that is happening. The age of your tv can determine this too. If your tv is a few years old or burned for 20,000 to 50,000 hours the caps could very well be bad. Hope this helps. Good luck.
Mar 08, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Grundig GU22 DVDP LCD TV. No image on screen.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 17, 2009 | Grundig GU22DVDPX 22 in. LCD TV
How to unlock a grundig t63-640?
Swich off tv from main swicher. Press i on remote control and hold it. Swicn on the tv from main swicher. On the screen should appear a service menu. Under decoder level with volume button from remote change from off to on. The same is with hotel mode for volume control. Exit the service menu by presing i on remote control and have a nice day!
Dec 27, 2007 | Grundig GF70-600 TV
Televison & Video Logo
Top Grundig Televison & Video Experts
Raj Patel
donny ardalando
donny ardalando
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
