Question about Samsung Washing Machines
Got a problem with samsung wobble technology 12kg with 4E error.. it was already checked by samsung repair center, the valve was replaced but it still shows 4E error.. what else could be the possible problem..
  • 3 Answers
SOURCE: Samsung washing machine J1453. Error
Had a same fault code and also sometimes had the reverse kept filling - soultion was that the small flexible pipe up to the pressure sensor had a crack (fatigue mahine was only 1.5 years old) in it next to the sensor - found it by sucking and blowing down the pipe while it was not connected to the sensor (with the electric off ) - Replacment pipe can be found at any good local washing machine parts shop/store
Posted on Jul 11, 2008
  • 13 Answers
SOURCE: Washer keeps displaying '4E' Lack of water error
If you have pulled out and cleaned the filter at the back of the machine where the hose connects then I would check that your pump is not running during the cycle and also make sure your drain line is at least half way above your drum at its highest point, If its too low then it will drain off even if the pump is not running.
Posted on Apr 11, 2009
SOURCE: 4e code
i have problem error 31( E31) please advice me to solve this problem
Posted on Apr 14, 2009
blueextc3221
  • 15935 Answers
SOURCE: 4E showing on Samsung Washing Machine
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: 4E error....samsung J845
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
I have a samsung front loading washer and I am getting error code 4E and cant find book help
Water supply problem causing a 'time-out'.
The 4E (4C) error is displayed on the panel of my washing machine ...
www.samsung.com/.../the-4e-error-is-displayed-on-the-panel-of-my-washing-machin...
  1. Cached
4E (4C) ERROR. The 4E (4C) error indicates that the washing machine has detected that there is a problem with the water supply. The most common reason for this error is a blocked or kinked water supply hose.
There are videos here
samsung front load washer error codes 4e Google Search
Apr 05, 2018 | Samsung Washing Machines
Tip
Samsung dishwasher error codes
Samsung Dishwasher Fault Codes
4E Water Inlet Valve Clean and /or replace
5E Drain problem Check drain hoses
Replace drain pump
LE Leak Check for leaks
on Apr 14, 2015 | Dishwashers
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Have samsung sw5ousp 5kg it is showing 4e water error any help b great thanx in advance
    The Error indicates that the water level did not increase or fill in time to the machines estimation . 4E WATER SUPPLY ERROR Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON. Check that the water valves are fully open check that any fill lines that have washer hose filters in them are clean check you source water pressure is OK
    If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
    Apr 18, 2016 | Samsung Washing Machines
    Samsung front load washing machine, WF42H5200AF, less than 4 months old giving code 4e when warm or hot temperature is pushed. Can only wash in eco warm or cold. I have drained and cleaned out to front...
    Error code 4E is a water supply error.
    Check the following:
    • Foreign material is entering the water supply valve.
    • The water supply valve terminal is not connected.
      (Wire disconnected)
    • The warm water and rinse connectors are wrongly connected to each other.
    • This occurs if the PCB terminal from the drain hose to the
      detergent drawer is not connected. Check whether the transparent hose is folded or torn.
    Possible Parts Affected are:
    • Water supply Valve
    • Main PCB
    • Obstruction of the water line.
    To Check the water supply:
    Check the resistance for the water supply valve. Resistance: 0.9~1.1k? between the terminals of the water supply valve
    Jan 28, 2015 | Samsung Washing Machines
    Samsung DMR77LHS Tall Tub Dishwasher displays HE code (flashing) and does not finish the cycle. I am very handy and would like to repair this myself. so as much detail as possible is appreciated.
    EE1/HE/HE1
  • The EE and HE codes refer to temperature errors. The EE1 designation refers to a thermistor issue, and the HE codes refer to heater problems. These are all functional errors that require a certified service technician, but disconnecting the circuit breaker in the meantime can prevent the problem from growing worse.
  • 4E/4E1
  • The 4E codes indicate a problem with the water supply. If you see the 4E code, make sure the water supply line is correctly attached and open and not frozen or clogged. If you get a 4E1 code, check the temperature of the incoming water supply and ensure that it is below 176 degrees. If either of these issues persist despite your best efforts, contact a repair center.
  • 5E
  • The 5E code means there is a problem with the drain. Make sure the drain hose and openings are not clogged or obstructed. If they are not, and the code remains, disconnect the circuit breaker to reduce the risk of electric shock and contact a service center.
  • oE/9E
  • The oE and 9E codes refer to issues with the water level. The oE code means that the dishwasher is filling too much, and the 9E code means it is not filling enough. Disconnect the circuit breaker for safety and contact a repair center.
  • LE
  • The LE code indicates a leak. To keep from voiding your warranty, do not attempt to diagnose and repair the leak yourself. Close the water supply valve and disconnect the circuit breaker to avoid electric shock and contact a repair technician.
  • 6E2/PE
  • The 6E2 and PE codes both indicate functional errors that must be repaired by a professional. The 6E2 code indicates a pressed key error, and the PE code refers to a problem with the half-load function. Disconnect the circuit breaker in either case and contact a repair service.
  • Jan 14, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
    My dishwasher model number dmr77lhb is showing error code le and there are no apparent external water leaks how can I rest
    I fixed mine by pulling out the unit then flipping over to access the white tray that covers the bottom of the unit. Remove this then dry it out...there's a sensor in there that triggers the LE code. It could be a leak but in most cases it's just built up condensation. EE1/HE/HE1
  • 4E/4E1
  • 5E
  • oE/9E
  • LE
  • 6E2/PE
  • Jan 10, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
    My Samsung dishwasher has a error code 4E after i start it up could you please let met know what this means thanks
    Most common error codes that are caused by installation errors are:
    • 4E. If your dishwasher is displaying error code 4E, it can be caused by the water supply valve. The water supply valve may be closed, or not fully open. Most water supply valves are not frequently opened or closed. Because of this, they may be difficult to turn. To make sure this is not your issue, turn the supply valve to the fully closed position, clockwise, and then turn the valve to the fully open position, counterclockwise.
      • Check your water pressure. Your dishwasher requires a minimum of 20 psi and a maximum of 120 psi.
      • Water filtration info.
    Nov 14, 2010 | Samsung DMR57LF Builtin Dishwasher
    Apr 11, 2009 | Samsung Washing Machines
    Washing Machines Logo
    32 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
