SOURCE: singer sewing machine will not zig zag
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Denatured alcohol is fine, surgical spirit too, different countries have different names or products, essentially alcohol with few impurities that will evaporate quickly with little residue.
Hope this does work for you, tho' as I said, it may take a little time to penetrate depending on severity........the same applies to the reverse mechanism of many machines when they seize.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
SOURCE: Zig Zag Not working on my Bernina 830.
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps.
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions [email protected]
SOURCE: Whenever I zig zag my machine skips stitches.
Try these solutions.
* Re-thread your needle
It may be threaded incorrectly (backwards).
* Reinsert your needle
Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the
flat side away from the bobbin, but consult your machine’s manual to be sure.
*Change your needle
Your needle may be blunt, bent, or otherwise damaged.
*Your fabric may require a different needle. Generally, heavier fabrics require larger needles and
thinner fabrics, smaller needles. You may also need a larger needle if
you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for wovens (or a universal needle for either).
And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot
It may be too light for your fabric.
* Change your thread
If your upper thread and bobbin threads are different types, try using the same thread for
both. And use a good quality, brand name thread.
* Adjust your thread tension
It may be too tight or too loose.
* Re-thread your machine
It may be threaded incorrectly.
* Change your needle plate
Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important: If you change your needle plate, check to make sure your needle aligns perfectly with
this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which
could be dangerous. And make sure to change your needle plate back for zigzag and other wide
stitches.
I hope this helps you.
Testimonial: "great advice!"
