SOURCE: Crosley Front Load Washers FL Error
Flood Condition F L “FL” flashes if any overfill condition occurs. This condition occurs when excessive water in
the tub causes the overfill switch to trip. The control must realize that the trip was due to an
overfill condition instead of a suds lock condition in order for “FL” to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out.
The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch
resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
SOURCE: Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
SOURCE: spin cycle won,t spin. starts then stops
It doesn't spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
SOURCE: Our Crosley washing machine (Model
Three possibilities here,
One, you've overloaded the washer with clothes, throwing the washer basket on tilt because of the extra weight and force against the agitator. Remove the wet clothes from the washer and try continuing the cycle.
Two, One of the elastic/spring arms that centers the basket inside the washer housing has broken and is allowing the basket to simply flop around. Disassemble the washer and inspect the basket supports.
Three, The center post that the washer basket sits on is going bad - The most common reason is that the bearings have gone bad. Disassemble the washer and replace the bearings at the base of the basket where it connects to the motor.
