Question about Kitchen Ranges
Ped097 ignition cycles after burner lights then clicks about 7 times then relights.put in ignition box still does the same thing any thing you can do to help
    Top Expert:
  • Kitchen Ranges Master
  • 57,236 Answers
Sadly there is not
Posted on Jan 12, 2019
jsrock516
  • 5911 Answers
SOURCE: After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Posted on Apr 29, 2007
jsrock516
  • 5911 Answers
SOURCE: Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Posted on Jul 18, 2007
  • 26 Answers
SOURCE: Pilot goes out after heating cycle
Check regulator on the unit.
Check pilot unit on the heater
use soapy water to check for leaks if see bubbles turn off main gas supply valve.
always turn off gas supply before any checks or repairs are made
when all else failes call your local gas provider to check heater and gas supply
Posted on Dec 16, 2008
  • 63 Answers
SOURCE: Igniter clicks on the wrong burner
The spark supposes to go to all burners. The spark igniter of the non working burner needs to be replaced.
Posted on Sep 26, 2009
TheMobilian
  • 8220 Answers
SOURCE: Sealed gas cooktop. Igniter keeps clicking.
I have 2 videos for you:
Burner replacement
Burner switches
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 19, 2009
My Atwood GC10A-3E will come on the first time I flip the switch. After that it will not relight until I turn it off and back on. When it relights it sounds like an explosion in the tube. I feel it is...
Sounds like some adjustments are needed. Air shutter for one, and ignitor/electrode. Have you by chance observed outside with cover open when it tries to re-light? My guess is that it is sparking/trying to ignite, but adjustments are needed for proper ignition. A good cleaning of burner tube, electrode, and proper adjustment of electrode & air mixture should cure your problem.
Sep 10, 2013 | RTO Atwood DSI-RV Water Heater-6 Gallon
Burners will not light
Hello bdrillbit - Is the electronic igniter aligned properly? Ensure that tip of spark igniter is aligned with metal point or "nib" located on underside of burner cap after the burner mounting screws have been tightened. (Not all burners having mounting screws). When the burner control knob is set to the "LITE" position do the igniters spark? Can gas be heard or smelled coming from the burners when the control number is turned on? However, if you smell gas, I highly recommend turning the unit and the gas off if you can reach it and contact your gas provider. The range itself does not have a switch or regulator to relight it. Keep in mind that it may be experiencing an issue with the spark module, electrodes, wiring or EOC.
Feb 12, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Baxter OV-210G burner cycling on / off @ 90 sec, repeating after new burner blower
You need to clean the flame sensor or replace the flame sensor.
Sep 30, 2017 | Heating & Cooling
My Hotpoint gas dryer won't relight after it has
Your gas valve electrical coils have gone bad. They are easy to replace.
Jun 21, 2011 | Hotpoint Dryers
My heater is cycling on and off it will run for a while and than the red service light comes on for about 4 or 5 minutes than it relights and runs again
Pull the lower front panel and inspect the top of the burner. If there are ashes and debris on top of the burner, especially near the ignitor, then clean it off.
Jun 09, 2010 | Pentair Minimax Ch 400,000 Btu Propane...
Hello - I ran out of propane - How do I light the ignition?
Your range is electric ignition and should not require any relighting. There may be air in the line and can be purged at the cook top burners. Just turn the burner knob on until it starts clicking and let it click until the burner ignites. The oven and broiler will then light normally.
Feb 05, 2010 | GE JGBP28 Gas Kitchen Range
When lighting any burner...the igniter continues after lighting."click, click, click, click, click" and so fourth. Thank you for your time.
My parts list doesn't tell me if that is an auto relight unit or not. But since you say it happens on any burner I'll leave out stuck ignitor switch for now.
Check the house ground wire to the unit and check that the burner caps are installed properly. The auto units read a ground when they ignite so if the burner caps are on wrong or dirty they can cause this.
jim
Jul 27, 2009 | GE 30 in. JGP326 Gas Cooktop
Clicking noise at the gas valve/pilot light unit
It sounds like you might have a spark igniter on the unit that is being told to relight the burners. This is probably the tstat as this is the only control that "tells" the unit to come on. There isn't anything else internally that will cause this problem. Replace your tstat and I bet this solves your problem.
Apr 05, 2009 | Carrier 38BRC048 Air Conditioner
Kenmore Oven Mod# 665.75012104
hi. thanks for the question .i would replace the bake igniter. that will solve your problem. happy graduation .thanks the appliance doc
May 07, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Stove top difficult to light
your gas jets are dirty.. clean them with a toothbrush (after everything is cooled down).. you can use the selfclean to clean the iron pieces that cover the burners..
be careful with kitchen aid self cleaning.. there is a known issue with the thermal fuses blowing quite easily on most self cleaning cycles..
good luck
tpug
Feb 21, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
Kitchen Ranges Logo
26 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
