On CD player
SOURCE: ''check engine light'' illuminated, 1004 Hyundai, Santa Fe
If you live in the US, take it to qany Auto Zone store and thy will read the codes off for you, I would suspect any right thinking competitor would do the same, check if you don't have one near by.
Hope this is of some help.
Ed
SOURCE: PROGRAM KEYFOB FOR HYUNDAI SANTA FE
This is from the factory service manual of your car:
There is no onboard programming procedure for this vehicle. This vehicle requires special equipment be connected to the vehicle to program the keyless remote. Translation you need the dealer to do this.
SOURCE: Change serpentine belt 2004 Hyundai Santa Fe
it uses a spring loaded tensioner.use a breaker bar to rotate the tension and it should just come off.if u need a pic or anything else to do it let me know,
SOURCE: 2005 hyundai santa fe check engine light on...
Definition of P0171 is Applied to All Manufacturers
Powertrain:
System Too Lean Bank 1
Definition of P0174 is Applied to All Manufacturers
Powertrain:
System Too Lean Bank 2
SOURCE: Does a timing belt have to be changed at 5 years
Usually a timing belt replacement is based on mileage not age. However, I would have the belt visually inspected to make sure it still is in good condition. If the belt breaks it can cause serious engine damage. The inspection should cost you very little as most newer cars has inspection plattes that come off with a few bolts, you could even do it yourself. I would think that you are fine, but better safe then sorry. My hyundai elantra went for 120,000 miles with the same timing belt and is still going today with its new owner.
