It quit putting out sound so technician set it back to factory settings and replaced battery, but now the Gm bank is the only one that is correct. the combination & program settings have one sound only. There are 100 sounds for each that don't play
SOURCE: HP desktop- had virus- reset computer, now no sound
Hi , to install sound driver.
open the control panel ,install sound driver and also check device driver view if the sound connect to computer.
SOURCE: how do i reset my yamaha dx 100 back to original factory settings
yamaha dx100 reset. Press voice switches 1 and 2 while turning power switch on. Display will say test entry?. press the plus/yes button. This will reinitialize all memory to factory settings. Also the lithium ram backup battery voltage will be displayed as check level with a number representing the battery voltage. The number will be 10 times the actual battery voltage. A new battery will display 33 representing 3.3 volts. If your reading is below 22 then your battery is shot and will need replacing and if you turn the unit off it will probably get a scrambled memory again.
SOURCE: Panasonic SA-HT680 DVD Home Theater Sound System
when i turn my home theater system on it says f61 then it shuts off can u plz help me out here =[
SOURCE: hello there how can i
press knob 1 and 2 and rec at the same time , then power on , then knob bank D , power off and on ,,,,, ready
Greetings Gerrie ( Holland )
