Lands Phones Logo
P
Paula C Livingston Posted on Jan 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic KX-TGD530W does not have dial tone - Panasonic Lands Phones
Jay Plesset
Level 3:
  • Panasonic Master 2,942 Answers
  • Posted on Jan 12, 2019
Jay Plesset
Panasonic Master
Level 3:
Answers
2942
Questions
Helped
668544
Points
9879
The most common cause of "no dial tone" is not plugged into live phone line. The dial tone comes from the line, not from the phone.
5 Related Answers
Anonymous
  • 201 Answers
  • Posted on Nov 19, 2007
SOURCE: Stuck on Night Mode
Your phone can work on different Panasonic phone systems that program differently. I would need to know the model number of your phone system to look up specific information.
Until I get that info from you. Most systems can only be turned on and off from night mode at one phone station (usually the operator) but others will let you program a programmable key on any phone to do this. It's also possible to enter a function code from any phone on some systems.
Does it say Night Mode on a display? How do you know it is in night mode? If it is on a display, is it on all the displays or just one? If just one then that is the phone that can turn it off.
Anonymous
  • Posted on Jan 17, 2009
SOURCE: panasonic KX-TGA236JXS gigarange phone is dial lock
panasonic KX-TGA236JXS give error dial lock
Anonymous
  • 14 Answers
  • Posted on Feb 16, 2009
SOURCE: panasonic KX-FT73 dial lock
Press the menu key twice and enter the password. If you don't know it, key in menu#9000*550 start
Anonymous
  • Posted on Jan 28, 2010
SOURCE: Panasonic KX-TGA601CB cordless phone Was working
phone says move closer to base
Anonymous
  • Posted on May 03, 2011
SOURCE: "Panasonic phone Model no.KX-TSC35MXW DIAL
how i can solve the restraction of calls
Panasonic KX-T7736 phone. 2 line system. 1 line is functioning correctly. the other line does not produce dial tone; when selected, I get a busy signal. This is not a new installation.
If you have a Panasonic KX-T7736 phone with one line not producing dial tone, there are a few possible causes. The first possibility is that the phone line itself is the problem.
If you have another phone in the house, try plugging it into the same phone line and see if you get a dial tone. If you do, then the problem is with the KX-T7736 and not the phone line.
The second possibility is that the problem is with the phone's internal wiring. To check this, unplug the phone from the wall jack and plug it into a different jack. If you get a dial tone, then the problem is with the first jack and not the phone.
The third possibility is that the problem is with the phone itself. If you've tried the other two solutions and you still don't have a dial tone, then the problem is most likely with the KX-T7736 and you'll need to contact Panasonic for assistance.
I hope this helps!
1helpful
Changing from pulse to tone panasonic phone
Touch the following keys: Menu 0 5 1 and then select 1 (tone, the factory default) or 2. Then Save (a softkey with the label in the LCD screen) and Off (opposite Talk on the keypad).
The manual for the Panasonic KX-TG5664 is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/KXTG5664.PDF . See page 17 for setting the Dialing mode.
I hope this helps.
Panasonic kx-tg2511e two-tone dial tone
It's stutter dialtone and indicates you have voicemail. Once you clear your voicemail the stutter tone will go away. You may also have a visual indicator that you have voicemail like a light or icon on the display.
1helpful
2helpful
Change pulse into tone
Go to the menu and choose Tel line and the go to set dial mode and then choose the dial mode like dial or pulse mode
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
2answers
Panasonic KX-FM220 fax machine does not have a dial tone
is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
Panasonic cordless phone KX-TG6052
reset the dial mode if it is on tone and you have pulse it will not dial out.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
