Question about Maytag Dishwashers
The dishwasher makes no sound after the cancel button pushed and turns off after a minute.
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
SOURCE: Dishwasher not draining
The problem is a clog in the hose or the check valve from the drain pump. I will post back shortly with directions to unclog it.
Thanks/Mike
Posted on Jan 13, 2008
SOURCE: dishwasher not draining - Kenmore dishwasher model 15754
depending on the age of this unit it may have food blocking what is called the "check valve".
on most models it is mounted right on the outlet of the pump housing. one model uses a 4 inch plastic tube style device and is about 1/2 inch on the pump and 1" on the hose. inside of it is where the food items can block the check valve. remove the hose and unscrew the check valve from the pump and see if something is blocking it.
on newer units the check valve is built into the drain hose, if you hose has a 90 degree elbow molded into it where the hose hooks up to the drain pump. once again take the hose off and look inside the hose or try to blow through the hose and see if the hose is clear.
good luck tom
Posted on Dec 31, 2008
SOURCE: Maytag dishwasher not draining fully
Try cleaning out the air gap. The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly. Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter? There is a filter located underneath the machine that should periodically be cleaned. To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Posted on Aug 01, 2009
SOURCE: Water in Dishwasher Bottom
Hello Richard, Welcome to Fixya ! You've come to the right place. The problem you're experiencing unfortunately is a common one. The water inlet valve has been an issue with B/S/H built ( this includes bosch, thermador, seimens & gaggenau ) dishwasher's going back to the mid 90's. The part to repair it is available at most brick & mortar appliance part centers or you can check out on-line vendors such as repairclinic, apwagner etc. Do a search for part # 1105846 at repairclinic, you'll see what I'm talikng about. By the way it's about $35. Hope that helps move you forward. Let me know if I can assist you further, or need help on how to change it etc. It's relatively easy with Bosch. Thanks for coming to "fixya" for your inquiries and please take a second to rate this answer according to my helpfulness. Goof luck. Macmarkus :)
Posted on May 04, 2010
SOURCE: The lights on the dishwasher
Sorry to read about your problem, I hope this helps you out.
You may have a defective pump, on a control card issue...
you may also try to reset the circuit breaker, and see if that helps. If not i suggest you contact a service company.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 26, 2010
Testimonial: "thanks for your help "
Jan 02, 2011 | Maytag Dishwashers
Jan 13, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Oct 01, 2010 | Maytag Dishwashers
Sep 23, 2010 | Maytag Dishwashers
Mar 01, 2018 | Bosch 24 in. SHU43 Built-in Dishwasher
Jan 15, 2010 | Dishwashers
Dec 16, 2009 | Maytag MDB6701AWW 24 in. Built-in...
Aug 01, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Apr 04, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Oct 27, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
62 people viewed this question
