Hi my Hoover Washing machine HNL 6166 has become very loud on a full spin (like sitting next to a plane taking off) can someone please help/advise
SOURCE: washing machine
i had the problem of my brand new washing machine not taking the conditioner and the customer service advisor rightly guessed that i was using concentrated liquid and advised me to dilute it with warm water then put it in the drawer because sometimes the liquid is too thick for the machine to take.try this!!!!! regarding the powder why not put it directly in the machine or buy tablets and do the same with those
Posted on Sep 10, 2008
huuum
  • 750 Answers
SOURCE: my hoover hnl 6166 washer
Hello Ryandc,
Welcome to fixya,
How old is the front load washer?
Front load washers have this problem no matter what brand or how much you paid for them, IF you are putting to much detergent in them.
The front loaders call for HE (High Efficent) detergent which is concentrated and needs less.
Or especially any liquid detergent not HE you must use use less.
To much causes the seal and bearing to wear out prematurely,
And or the front seal of the door to deteriorate into the water which can cause these stains on your clothes!!
Under these circumstance's they will go in about 5 years!
The only other time I saw colored streaks was when a guy left a pen in his pocket and that was for only one wash!
How old is the washer and did you buy it new?
I'm sorry I could not be the bearer of better news!
God bless You! Huuum
Please remember to leave a solved rating.
Here is an article I just read that you may find interesting!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not forget to give me a solveda rating before you sign off!
Posted on Oct 03, 2008
ginko
  • 19396 Answers
SOURCE: hoover nextra optima HNL 6166
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
Posted on Oct 16, 2008
SOURCE: hoover hnl 6166 not spinning
have you tried cleaning the filter at the bottom. remove the front plateat the bottom and there is a small round plate at the left. this has a screw in it. when you have removed this you give it a twist. a bucketload of water and gunk will come out. i found about 60p in 5's but when it was all removed it started to work again
Posted on Feb 05, 2009
  • 3 Answers
SOURCE: my hoover washing machine wont spin and is full of
It's a safety feature that doesn't allow the machine to spin when there's still water in the tub. The drain pump has probably failed and you would need to replace it (there are some good places online where you can buy appliances spare parts). Try to set your machine on a 'Drain' cycle and see if the pump works.
Posted on Nov 05, 2009
Hoover nextra washing machine model hnl 6166. how do i replace noisy drum bearings
If you are mecahical inclined look up the model and seriael
# on the web. ask them to send you a book of maitence on it and this should show you how and where the bearings are and where to get new and how to replace them.
May 10, 2011 | Hoover Washing Machines
Hi the belt on our hoover hnl 6166 nextra will not stay on. The motor and the drum seem to be out of alignment and there are no broken screws or bolts or wobbles. Any ideas please? Thanks Robert.
I would suggest that the drum is out of alignment because the main bearings have failed, or the drum shaft has collapsed due nto corrosion.
Spin the drum by hand, and listen for any noise, there should not be any, and see if the drum rotates centrally in relation to the outer drum
Feb 02, 2011 | Hoover Nextra HNL 3166 Z Front Load Washer
My hoover washing machine wont spin and is full of water. model number is hnl 9146-z
Nov 02, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
How do you remove the filter for a Hoover washing machine Optima Nextra Model HNL 6166?
I included a link on Youtube to my Nextra where I show how I clean the filter (watch it from 08:55 onwords). Just remove the kick strip and unscrew (philips screwdriver needed) the little screw on the filter itself, then turn it anti-clockwise but while you're doing this make sure you insert the kick strip underneath to gather the residual water. Repeat this operation 3 o 4 times until the sump is totally empty, make sure you don't let the kick strip fill up too much otherwise you'll be spilling water all over the place, so just turn the filter clockwise everytime you want to stop the trickle of water. It's not too complicated and it won't be too messy if you follow these instructions carefully. Good luck ;-)
Oct 25, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Hoover HNL 6166 6kg A+AA 1600 washing machine....smell of burning like burnt rubbber...........
Hi.
It is very likely you need to replace the motor brushes. These are the electrical conections in the motor that wear after a time. They are fairly cheap, uses-replaceable, and available from online appliance specialists.
Turn off water and unplug before removing top/ back pannel to access motor. ***** CHECK MOTOR TYPE BEFORE ORDERING PARTS ******
Sep 30, 2009 | Hoover AAA160 Front Load Washer
I need a user manual for a Hoover washing machine model HNL6166
http://service.hoover.co.uk/manuals/Manuals.aspx?Section=11
Just make sure you don't put a space between HNL and 6166. ie; HNL6166. The owners manual is there. Hope this helps.
Aug 30, 2009 | Washing Machines
Washing machine
Hoover washing machine This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 19, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Hoover hnl 6166 not spinning
Jan 07, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
