Check to see if there is a manual for your blower at this web site.
I FOUNG THIS WEB SITE that I think will help you with this question and a lot more. Since this web site will have access to many different vehicles I hope you do not feel like I am lazy by just passing along the web site instead of giving you the exact information you asked for.
Go to this site to find a manual to help you.
https://www.browsemanuals.co/lander_zrk65_test14.html?t1=1535071160&t2=65192170713&t3=kwd-28425796&gclid=EAIaIQobChMI-oybpN624AIVwdVkCh2GtguWEAEYASAAEgJ9yvD_BwE
SOURCE: linkage hook up for a briggs and stratton engine
wow, i have not ran into this problem yet. I am not getting any results for that engine in my usual locations, which have great diagrams. here is a link to the only diagram i can get a hold of. hope this works.
http://www.m-and-d.com/pdfs/briggs/135200-ms2810-0802.pdf
SOURCE: briggs & stratton 190707 wiring diagram
make sure your coil has not move ajust to 010. gap check magent on flywheel.see if strong.if all is ok yes coil is bad
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
SOURCE: how do you hook up the throttle on a briggs and
Good site for info:
bsppwebtools.com/data/manuals/1678_0esfw.pdf
