Question about HP Office Equipment & Supplies
I have this HP Laserjet p3005 and its printing blank on paper even when i change the toner cart. it is still printing blank and nothing show on the paper
68.2 permanent storage write fail
electronacs
  • 19 Answers
SOURCE: Permanent Storage Write fail
It appears that there is a problem with either the internal hardrive if you have this option installed, or the removeable Jet direct card if you have one installed, thirdly, it could be bad memory or the main board.
Go to HP's website and perform a firmware upgrade for your model if there is one.
I would first remove any add on option like networkcard, memory .... then turn the machine back on and see if the error goes away. You can also go through the menu and perform a fatory reset, this however in the process loose your IP address.
Onece you have aliminated the options I would move onto the main board or FIRMWARE
Posted on Jul 07, 2009
SOURCE: error 68.2 permanent storage write fail (Hp laserjet P4014n)
Hi kgrema! I will be glad to assist you in this issue,
Usually all you have to do is initialize hard disk even if you do not have one. Just turn off the printer. Turn the printer back on and when the memory starts to count hold down the menu key until all three lights come on. When all three lights are on solid release the menu button and press the arrow back button and initialize disk should appear in the menu. Just hit the check mark button again and it should take care of the problem.
Here is the link just incase it does not solve the issue.
HP Support document
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpl12422&jumpid=reg_R1002_USEN#A46
I hope this will solve your issue
Posted on Oct 26, 2009
shishirgarde
  • 114 Answers
SOURCE: HP Color LaserJet CP3525 68.X PERMANENT STORAGE
Perhaps this link may help you !
http://h200003.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=de&cc=de&taskId=125&prodSeriesId=74301&prodTypeId=18972&prodSeriesId=74301&objectID=bpl11648
Posted on Nov 01, 2009
brett207
  • 231 Answers
SOURCE: the printer keeps printing in landscape form even
This sounds like a software problem...
Try using the PCL5e driver instead.
Posted on Jan 27, 2010
  • 10 Answers
SOURCE: HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Posted on Jan 29, 2010
HP Laserjet P3005, everytime we print we get black speckles in 7 even lines across the paper. Why is this?
Usually caused by the toner cartridge, try replacing the cartridge. Especially if it is not a genuine HP cartridge they have a higher defect rate.
Jan 17, 2011 | HP LaserJet P3005n Printer
My laserjet p3005 is not printing properly. there are 6 blank horizontal stripes across the page.
This is almost always going to be the toner cartridge. Swap it out if you have a spare. If not even if you have an empty one, just shake it a bit and put it back in to see if the blank lines go away. It is at least 90% chance or better that the problem is in the cartridge.
Good Luck and Thank You for using Fixya.
WheatlandServices
Oct 20, 2010 | HP LaserJet P3005 Printer
My HP P3005 prints blank pages
Please check the cartridges it see if the toner is finish,clean the print head because it may be block up or you can replace it if it is damage.
Aug 15, 2010 | HP LaserJet P3005 Printer
HP P3005 - skid marks along paper's edge
Print 3 pages. Use the manual feed tray. As they print, open the cover, remove the toner and look down at the paper in the printer. Do you see marks along the edge? If no...replace the fuser. If yes...it could be the transfer roller.
Jan 07, 2010 | HP P3005d Monochrome LaserJet Printer
Changed toner cart. do to void in middle of print
My whole day, today, was filled with dealing with bad toner carts.
Even new genuine ones from HP
6 service calls., 6 bad carts.
Aug 19, 2009 | HP LaserJet 5p Printer
Printer prints blank on paper
Open the door half way through a page print and pull out toner cartridge. The page should be in the toner cartridige. If you can see the printed image then the fuser is the problem if you see nothing then the toner is bad or has a protective sleeve inside that needs to be pulled out from one of the ends.
Jan 08, 2009 | Canon LBP 800 Laser Printer
Lazer not scanner
If I am not mistaken you are getting blank paper when you give printing command am I right if yes........
every laser printer has one data scanning and transferring data to toner drum unit in it.
BLANK PAPER PRINTING PROBLEM ONLY LINKED WITH
1. TONER CARTRIDGE PROBLEM OR
2. SCANNING UNIT OF YOUR LASER PRINTER PART OF YOUR LASER PRINTER.
CHANGE TONER IF PROMLEM IS SAME THEN IT IS CONNECTEE TO SCANNER OF YOUR LASER
IF NOT SOLVED MAIL ME TO inkcity@rediffmail.com
Jun 01, 2008 | HP LaserJet 1012 Printer
NEW HP LASERJET P3005
Paper keeps jamming under guide plate.....and buckels. Require to remove toner cart. and pull back spring loaded plate and remove jammed paper. This happens after printer sits for 1 day. If I can finally get it to print, it will continue to work.
Apr 24, 2008 | HP LaserJet P3005n Printer
57 people viewed this question
Clive
Clive
