Question about Hyundai Car Audio & Video
I have 05 hyundai XG 350. The wire harness was cut so im wiring aa cd player and new harness together.. The are throwing me off. I have 2 yellows a black wire with white stripe. One green with a brown stripe.. A. Blue and a tannish color one.. Which is the ignition .. The battery and the ground
    Top Expert:
  • Hyundai Master
  • 6,815 Answers
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 yearsmust try this bitman and reliable-store. Both are good
Posted on Feb 06, 2019
SOURCE:
simplemitch
  • 752 Answers
SOURCE: Wiring Problems
You didn't cut the plastic connectors off the factory wiring, did you? One is gray and one black.... if not, just get to a stereo shop and buy a wiring kit for your car and all colors will match. They're about $10. If you DID..... well..... we have a LOT of work to do....
Posted on Sep 11, 2007
johnny5846
  • 379 Answers
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Posted on Jan 10, 2009
  • 30 Answers
SOURCE: Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Posted on Apr 12, 2009
smartr10U
  • 1305 Answers
SOURCE: need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
Posted on May 31, 2009
etirbynnor
  • 655 Answers
SOURCE: ok, here is a list of the factory wires coming
Hello jlharris28, Here's the color code for the '92 Sentra: Radio Constant 12V+ Wire: Red/Black Radio Switched 12V+ Wire: Blue Radio Ground Wire: Chassis Radio Illumination Wire: Red/Blue Radio Dimmer Wire: Red/Yellow Radio Antenna Trigger Wire: N/A Radio Amp Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): Blue/White Left Front Speaker Wire (-): Blue/Yellow Right Front Speaker Wire (+): Brown Right Front Speaker Wire (-): Brown/White Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Red Left Rear Speaker Wire (-): Green Right Rear Speaker Wire (+): Blue Right Rear Speaker Wire (-): Pink It's better to use an aftermarket wiring harness that plug into the vehicle wiring. The Metra part number 70-1763 seems to be the correct one for your vehicle. Hope this helps.
Posted on Aug 12, 2009
Testimonial: "thank you greatly. that does help alot."
I am installing a new cd player in my 2006 dodge ram single cab truck, i have made the mistake of the cutting the stock wiring harness plug. Now i need to know what color codes are on these wires so i can...
Hello my name is Israel. I have added the following informaiton to help you out. Good Luck.
Radio 12v gray/red + radio harness
Radio Ground black and black/lt. green - radio harness
Radio Ignition pink/yellow + radio harness
Radio Illumination orange/tan (dimmer) + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- dk. grn/yel - dk. grn/lt. blue +,- radio harness or amplifier
Notes: The amplifier is behind the glove box.
RF Speaker +/- gray/yellow - gray/lt. blue +,- radio harness or amplifier
LR Speaker +/- gray/lt. grn - gray/dk. grn +,- radio harness or amplifier
RR Speaker +/- dk. grn/lt. grn - dk. grn/gray +,- radio harness or amplifier
Feb 21, 2011 | 2006 Dodge Ram 1500
I have a 1992 Saturn, took out the old radio, want to install a panasonic am/fm/cd player. I have a yellow wire from harness that is hot, and a black wire that is hot. I need to know how all these wires...
Yellow wire should be your remote turn on/12V source and the black is typically a neutral or ground wire. You should be able to connect to your car adapter wire for wire and the ones aren't being used I would just cut it and put black electrical tape around the end.
Sep 19, 2010 | Car Audio & Video
Memory erases everytime the ignition is turned
Be sure that the yellow wire from the cd player is connected to a +12 volt source. ONe god source is the orange wire from the cigarette lighter if the cigarette lighter is working fine. If not run a wire from the yellow wire of the cd player to the fuse block in one of the pins marked "bat". Good luck. Please rate.
May 26, 2010 | Kenwood KDC-319 CD Player
Need a wiring diagram for a 99 hyundai accent tape deck
1999 Hyundai Accent Car Stereo Radio Wiring Diagram Car Radio Constant 12V+ Wire: Red/Yellow Car Radio Ignition Switched 12V+ Wire: Blue/White Car Radio Ground Wire: Black Car Stereo Illumination Wire: N/A Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amplifier Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): White/Red Left Front Speaker Wire (-): Black/Red Right Front Speaker Wire (+): White/Blue Right Front Speaker Wire (-): Black/Blue Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): White/Red Left Rear Speaker Wire (-): Black/Red Right Rear Speaker Wire (+): White/Blue Right Rear Speaker Wire (-): Black/Blue
Jan 02, 2010 | 1999 Hyundai Accent
How do I remove the alternator from a 2002 V6 Hyundai Sonata once I have disconnected the alternator?
Removal
  1. Remove or disconnect the following:
    Negative battery cable Radiator mounting bolts, 1.6L only Alternator drive belt Alternator wiring harness connectors Alternator. It may be necessary to raise the radiator
Fig. Exploded view of the alternator-XG 300 and XG 350
Removal & Installation
    Negative battery cable Alternator drive belt Alternator wiring harness connectors Alternator. It may be necessary to raise the radiator 5ead6d5.gif
  2. Fig. Exploded view of the alternator-XG 300 and XG 350
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    Fig. Exploded view of the alternator-XG 350
  3. Install or connect the following:
    Alternator and reposition the radiator, if raised Alternator wiring harness connectors Alternator drive belt
  4. Adjust the alternator belt and torque the bolts to the following specifications:
    1. Accent: Pivot bolt to 14-18 ft. lbs. (19-25 Nm) and adjustment bolt to 14-20 ft. lbs. (19-28 Nm).
    2. 2.0L and 2.5L Sonata, Elantra and Tiburon: Pivot bolt to 14-18 ft. lbs. (19-25 Nm) and adjustment bolt to 105-132 inch lbs. (12-15 Nm).
    3. 2.4L Sonata: Pivot bolt to 26-41 ft. lbs. (34-54 Nm) and the adjustment bolt to 14-18 ft. lbs. (19-25 Nm).
    4. 3.0L Sonata and XG 300: Pivot bolt to 14-18 ft. lbs. (19-25 Nm) and adjustment bolt to 11-16 ft. lbs. (15-22 Nm).
  5. Install the radiator mounting bolts, if removed.
  6. Connect the negative battery cable.
I hope hrlp you with this. Good luck and remember rated this help-
Aug 25, 2009 | Hyundai Sonata Cars & Trucks
Broken wire in wire harness clip
i'm not sure what part is broken from your description but i will try to help...
you can purchase something called a reverse harness that looks identical to your vehicle's OEM harness that plugs into the factory radio. the only difference will be the wiring color on the new harness will be standard aftermarket wiring (ie 12volt yellow, ign red, ground black, etc.) and if you cut each wire from the OEM harness and solder it to the reverse harness location for location then the new harness will be good to go. i would personally do this as a single wire at a time so you are not staring at 16 cut wires going to the new harness. check at Best Buy and see if they carry the 71-1770 Metra wiring harness and that will be the one you need as the reverse harness and if you are installing an aftermarket radio get the 70-1770 also. if you aren't comfortable with all this your local installers should be able to do this job for you pretty reasonably.
Aug 18, 2009 | Pyle PLTDN71 Car Video Player
2002 malibu wiring diagram?!?!?!?!?!?!
ok, the red and yellow wires serve 2 different purposes.the yellow supplies constant power to your stereo, and the red is switched power. what youve done is combine the two, and connect them to a constant power source. like this, your stereo wont be switched with your ignition. so take off the red wire, but leave the yellow wire connected to the wire its already on. make sure your stereo fuse is good in the fusebox of the car. then, use a test light, with the ignition switch on, to find the second wire on your cars harness that has power. that will be your switched power. connect that one to your red wire, and that will solve your problem.
Aug 04, 2009 | Corvette Chevy Malibu 90-04 Car Radio...
Gauges dont work after new cd player install
you will have to go to the gm garage and ask for the wiring diagram to match the wires up. but the way to fix it the right way is to go to the junk yard and cut the harness out of a car and splice the wires back together then go to wall mart or best buy to get the right wiring adapter then you can match them colors up to your new radios wires and plug into your car
Mar 09, 2009 | Buck Oldsmobile Intrigue 1999 Radio...
I bought this 93 pontice firebird with no dash lights because they hooked up a cdplayer in it,an am trying to get them fixed what wires needs to be hooked back up?
try looking for the yellow wire from the cd player. find the wire that they connected it 2 and take it off. if they cut it 2 connect it 2 the yellow wire find the cut off bit and join original wire together. probly have to check the fuses.if not yellow wire mite b red. probly yellow tho.gud luck
Dec 08, 2008 | Car Audio & Video
Chrysler Part No. P56038933AB Radio Wire Color code
1982 to 2001 wiring harness color code Chrysler.
12V constant pink or pink/white stripe
12V accessory red/white stripe
Antenna/Amp turn on white
12V Illumination black/yellow stripe
Left front + dark green
Left front - brown/red stripe
Right front + purple
Right front - blue/red stripe
Left rear + brown/blue stripe
Left rear - brown/yellow stripe
Right rear + blue/ orange stripe
Right rear - blue/white stripe
there is no ground wire in the harness, the metal braided strap is the ground.
use a ring terminal,speed clip, and screw to attach the ground wire from new radio
when replacing infinity radios and speakers, there are 4 wires instead of 2 at the speaker plug. the large gauge blue and black wires are the power supply for the amp, the other 2 are signal wires from the deck and will match up to the wire color codes above. simply cap off the power and ground and use the other 2 for speaker leads.
One thing i hate to see is someone who just hacks off the plugs behind the radio because they are too cheap/lazy/dumb to buy a wire harness adapter for the nice new aftermarket deck they just bought. ive seen everything from masking tape to house wire nuts used to connect wires, and they never last.
there is only 1 reliable permanent way to connect wires together - SOLDER AND SHRINK WRAP!!! whether you're connecting wiring for a radio, fog lights,repairing a cut wire, etc solder those wires, you'll be glad you did when you never have a problem with that circuit again.
This is a listing for part #'s for dash kits wire harness adapters
all part numbers are metra unless otherwise noted
dash kit 99-6700, 99-6701 and 99-6500 will work for most cars
wire harness adapter 70-1817
reverse harness( to replace factory plug that have been cut off) 71-1817
speaker adapter plugs 72-6510, non amped 72-6513 when equiped w infinity system and bypassing fact amps
no antenna adapters are required until you hit 2002 model year.
beginning in 2005 chrysler switched to a high speed LAN system in all its cars and trucks. there is no longer a switched ignition lead in the harness.
Good Luck
Leadispenser
Aug 25, 2008 | Kenwood KDC-MP235 CD Player
Car Audio & Video Logo
46 people viewed this question
Top Hyundai Car Audio & Video Experts
Jude24
ray gallant
ray gallant
Are you a Hyundai Car Audio and Video Expert? Answer questions, earn points and help others
