Question about Toshiba Televison & Video
No menue button on my new Toshiba 43T6863DB how do I get int settings
  • Toshiba Master
  • 5,791 Answers
Unfortunately, you need the original remote or a universal remote with the coding and a menu button. On the original remote, the Menu button is the blue one with a house symbol; I'd call it a Home button. Here's a replacement remote for the 43T6863DB: http://www.remote-controls-shop.co.uk/catalogue/TOSHIBA/43T6863DB/ . For a universal remote to have the best odds of having the correct code, you need one that was programmed 6 months or more after the TV was built.
I hope this helps.
Posted on Jan 12, 2019
How to unlock a Toshiba blue-ray DVD player bdx2150 to all regions Please help Thanks
If the current firmware in your blu-ray player supports multi region then try this.
1. Power on the blu-ray player.
2. Press "Setup" on the remote to enter Setup Menu.
3. Using the remote, enter "8520". A new submenu will appear.
4. Set DVD region code to "0" for DVD Multi Region.
5. Set BD region code as required using the remote buttons.
"1" = Region A, "2" = Region B, "4" = Region C
6. Press "Setup" button to exit the menu.
If this does not work then try upgrading the bluray firmware.
Search for Toshiba BDX2150 firmware and see if there is a newer firmware than the one you have installed.
Nov 05, 2017 | Toshiba Televison & Video
28" Toshiba TV has no audio when TV is turned on. the speakers are fine as you can hear a video tape. need help
Check if the speakers are switched on in your Menu:
Press the AUDIO button on the Remote Control or the Menu button on the TV set to display the AUDIO menu. Repeatedly press the AUDIO button on the remote or the ADV button on the TV set until SPEAKERS is displayed in magenta
Press the + or - button to call up the SPEAKERS ON/OFF mode on screen display. Each time you press the button ON or OFF mode alternate. Make sure is is switched to on.
Also there is a switch on the back of the TV to control which speakers you use, it says MAIN SPEAKER EXT-INT make sure this is set to INT.
If this doesn't work you'll have to contact Toshiba service.
Hope that helps..........
Jul 01, 2008 | Televison & Video
Fix volume control
1. Go into the Set Menu.
2. Press the AMP button on the remote.
3. Press the Menu/Set Menu button.
4. Use the Arrow Up Down button to select Manual Setup.
5. Press the Enter button to enter Manual Setup.
6. Use the Arrow Down button to select the number 3 Option Menu.
7. Press the Enter button to enter the Option Menu
8. Use the Arrow Down button to select D Multi Zone Set.
9. Press the Enter button to enter D Multi Zone Set.
10. Press the Arrow Down button to get to Zone 2 Amp
11. Press the Arrow button to the right to set the Zone 2 Amplifier to INT.
12. Press the Menu/Set Menu button repeatedly to exit the Set Menu.
I’m happy to help further over the phone at https://www.6ya.com/expert/glenn_3b3dd885737c06f6
Aug 09, 2014 | Yamaha RX-V757 Receiver
I have a surface tablet unable to connect to wi fi
Solution 1 - Reset TCP/IP stack
To reset your TCP/IP stack, do the following:
  1. Right-click on the Start Menu button and open Command Prompt (Admin)
  2. Type the following command and press Enter: netsh int ip reset
  3. Reboot your PC and check if you're able to connect to WiFi network. If you can, you're good to go, but if not, type the following commands in the elevated Command Prompt and press Enter after each one:
  • netsh int tcp set heuristics disabled
  • netsh int tcp set global autotuninglevel=disabled
  • netsh int tcp set global rss=enabled
  • ipconfig /flushdns
Solution 2 - Re-configure WiFi Adapter
Maybe reconfiguring your WiFI adapter will solve the problem. To do so, follow next steps:
  1. Go to Search, type device manager and open Device Manager
  2. Right-click on your wireless adapter and go to Properties
  3. Go to Power Management tab, uncheck Allow the computer to turn off this device to save power and click OK
  4. Modify the default power plan, and switch it from high energy savings to low
Jun 30, 2014 | HP Compaq nc6000 Notebook
My new toshiba 32 inch regza turns on but thats all it does? no picture, sound even menu dosnt come up
First if a "new" set and if in warranty--have them deal with the problem.
If nothing on remote except on and off works--it is a micro problem (microprocessor) in the set.
I assume you did unplug the set---wait and plug it back as that could allow the micro to reset.
The key clue here is nothing on remote works except on/off?
Mar 30, 2012 | Toshiba REGZA 47HL167 TV
I WANT THE WHOLE CODE FOR THIS
This whole code for above we can not give.
Aug 06, 2009 | Shopnovell iFolder 1.0 Software Media Kit...
I need a complete workingsource code written in
This is a simple source code for Simple calculator in Java using RMI
//mathServer//
import java.rmi.*;
import java.rmi.Naming.*;
import java.rmi.server.*;
import java.rmi.registry.*;
import java.net.*;
import java.util.*;
interface mathInterface extends Remote
public int add(int a,int b) throws RemoteException;
public int subt(int a,int b) throws RemoteException;
public int mult(int a,int b) throws RemoteException;
public int div(int a,int b) throws RemoteException;
public class mathServer extends UnicastRemoteObject implements
mathInterface
public mathServer() throws RemoteException
System.out.println("Initializing Server");
return(a+b);
return(a-b);
return(a*b);
return(a/b);
public static void main(String args[])
try
mathServer ms=new mathServer();
java.rmi.Naming.rebind("MathServ",ms);
System.out.println("Server Ready");
catch(RemoteException RE)
System.out.println("Remote Server Error:"+ RE.getMessage());
System.exit(0);
catch(MalformedURLException ME)
System.out.println("Invalid URL!!");
//mathClient//
import java.rmi.*;
import java.awt.*;
import java.awt.event.*;
public class mathClient extends Frame implements ActionListener
Button B1=new Button("Sum");
Button B2=new Button("Subtract");
Button B3=new Button("Multiply");
Button B4=new Button("Divide");
Label l1=new Label("Number 1");
Label l2=new Label("Number 2");
Label l3=new Label("Result");
TextField t1=new TextField(20);
TextField t2=new TextField(20);
TextField t3=new TextField(20);
public mathClient()
super("Calculator");
setLayout(null);
l1.setBounds(20,50,55,25);
add(l1);
l2.setBounds(20,100,55,25);
add(l2);
l3.setBounds(20,150,55,25);
add(l3);
t1.setBounds(150,50,100,25);
add(t1);
t2.setBounds(150,100,100,25);
add(t2);
t3.setBounds(150,150,100,25);
add(t3);
B1.setBounds(20,200,80,25);
add(B1);
B2.setBounds(100,200,80,25);
add(B2);
B3.setBounds(180,200,80,25);
add(B3);
B4.setBounds(260,200,80,25);
add(B4);
B1.addActionListener(this);
B2.addActionListener(this);
B3.addActionListener(this);
B4.addActionListener(this);
addWindowListener(
new WindowAdapter()
public void windowClosing(WindowEvent e)
System.exit(0);
public void actionPerformed(ActionEvent AE)
if(AE.getSource()==B1)
sum();
else if(AE.getSource()==B2)
subt();
else if(AE.getSource()==B3)
mult();
else if(AE.getSource()==B4)
div();
public void sum()
int i=Integer.parseInt(t1.getText());
int j=Integer.parseInt(t2.getText());
int val;
try
String ServerURL="MathServ";
mathInterface MI=(mathInterface)Naming.lookup(ServerURL);
val=MI.add(i,j);
t3.setText(""+val);
catch(Exception ex)
System.out.println("Exception:"+ex);
public void subt()
int val;
try
val=MI.subt(i,j);
t3.setText(""+val);
catch(Exception ex)
public void mult()
int val;
try
val=MI.mult(i,j);
t3.setText(""+val);
catch(Exception ex)
public void div()
int val;
try
val=MI.div(i,j);
t3.setText(""+val);
catch(Exception ex)
mathClient MC=new mathClient();
MC.setVisible(true);
MC.setSize(600,500);
Jul 03, 2009 | Microsoft Computers & Internet
HOW TO ''INT'' THE ENTIRE OFFICE
This is a partial guess, because an EKT phone probably sits on a Strata. Try Intercom 60 for all internal, 68 for all internal/external if you have it, and 69 for external only. The missing numbers are 1-4 for zones.
If it happens to be a DK, try 3x instead of 6x.
Carl
Mar 23, 2009 | Toshiba EKT 6010 S Corded Phone
Remote Control wont open manue on new tv
ensure the satellite receiver is turned on and the output from the satellite receiver is connected to the ant. in on the tv. on the remote control, press the tv button, then the menu button. from the menu, select settings, set input to ant. .
do this and let me know what happens so we can get this working
I will be available till 2:00am CST
clarkco
Feb 16, 2009 | Toshiba 26AV502U 26 in. LCD HDTV
Alpine cda 7893 no sound
this radio does have setting to turn off internal amp go into menu and check it hold down set button to access menu I think
Nov 20, 2008 | Alpine CDA 7893 CD Player
Televison & Video Logo
43 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
