Question about Polaroid Televison & Video
How do I reset or at get back to normal tv on a polaroid smart tv that is stuck on Home screen when remote does not work
SOURCE:
  • 198 Answers
SOURCE: Daewoo TV Question
there should be some buttons provided on the dash board of your tv... just enter the menu using those buttons n reset it back to the original settings
Posted on Feb 20, 2008
TJBENGR
  • 121 Answers
SOURCE: Stuck in zoom
You should be able to get to the menu with the front panel buttons. Otherwise, try unpluging for a minute, this may allow a reset. Please do not rate me if this is no help.
Posted on Apr 25, 2008
  • 4 Answers
SOURCE: tc code for a polaroid tv
Gloria i work in an electronics store and have had many run ins with common universal remotes not having codes available for newer TV manufacturers. Most universal remotes are limited to 50-100 brands of telivisions. The problem is that recently many companies have recently started manufacturing TVs and it is at the discression of the remote manufacturer which codes they can accept. There is a solution but in many cases gets overlooked because of the price. Advanced Universal remotes are available ranged $75-$500 and can either access codes from an internet based database or learn from the original remote directly.
Posted on Jan 05, 2009
SOURCE: remote problems with Polaroid hd lcd tv
use a differerent remote
Posted on Jan 15, 2009
ginko
  • 19396 Answers
SOURCE: We have a 19" Polaroid flat screen TV along with a Polaroid remote control, which no longer works. The TV functions perfectly with the controls TV's built-in controls; however, the remote does nothin
Hi.
Please test the TV using a programmable remote. If the TV works using the programmable remote buy a replacement remote control:
NEW POLAROID REMOTE CONTROL TDA-03211C TDX-01930B
Polaroid TDX01930B Replacement Remote Control
Polaroid Remote Controls
Posted on Dec 09, 2011
I have a polaroid tv and how do I down load the specturm app so I can see my service on the TV?
  1. Ensure that your Samsung Smart TV is connected to the Internet.
  2. On your Samsung Smart remote, press the Smart Hub button to go to the Samsung Home screen.
  3. Scroll to and select Apps, and then select the Magnifying Glass icon.
  4. Enter Spectrum TV, and then select Done.
  5. Select the Spectrum TV™ App, and then choose Download.
  6. Once installed, select Open to begin using the Spectrum TV app.
  7. When prompted, enter your My Services Username and Password.
For further assistance, visit Samsung Support.
http://homenol.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 13, 2018 | Polaroid Televison & Video
Tip
How to Fix a Polaroid LCD TV Screen
<p>A Polaroid LCD TV delivers its picture via DVD player or cable connection to your home or office. After setting up your device and using it, you might experience technical difficulties with power loss and picture quality. Navigating through a few steps of self-maintenance will have your Polaroid TV running smoothly again in little time. You can examine your TV's power cord for damage, rewire a DVD player connection, and adjust your Polaroid's backlight.<br /> Difficulty:Moderate <span>Instructions</span> <ol> <li> <ul> <li> <span></span> Turn your Polaroid around so that the back is facing you, as a first step in correcting a power loss issue. Examine the length of the power cord from the back panel of the Polaroid to the wall outlet for damage, such as tears or rips. Replace the cord, if you see damage. Unplug the TV from the wall outlet and inspect the metal receptors (prongs) for dirt. If the prongs are dirty, clean them with a dry cleaning cloth. Plug a separate electrical device into the outlet and turn it on to confirm that the outlet is performing correctly. Plug the Polaroid TV back into the outlet, and try again.<br /> </li> <li> <span></span> Twist the Polaroid TV's back panel towards you so that the connected cables and jacks are easily accessible to you. If you're experiencing problems getting a picture from your DVD player, inspect the connection of the audio/video cables to your "Composite In" jacks. There are three cables in a standard audio/video setup: a yellow cable, a red cable, and a white cable. Unplug all three cables from their jacks to reset the connection. Insert the yellow-tipped cable into the "Video" port, which is yellow-colored to make matching the cables easier. Insert the white-tipped cable into the "L" (left audio) port and the red-tipped cable into the "r" (right audio) port. Perform the same steps on the audio/video cable out ports of the DVD player, and try again.<br /> </li> <li> <span></span> Raise the TV's backlight level, if you're having trouble seeing the picture. Push the "Menu" button (located on your remote control), and the TV setup menu will appear. Use the navigation buttons located on your remote control to scroll to "Image," and push "Ok" -- located within the navigational buttons on your remote control. A list of options will be displayed, such as "Contrast," "Hue," and "Saturation." Choose "Brightness" from the options. Use the four-way navigation buttons to raise the brightness (make your screen brighter and more illuminated) or lower the brightness (make your screen darker).<br /> </li></ul> </li></ol>
on Dec 27, 2010 | Televison & Video
I'm trying to connect my Polaroid 15" LCD TV (model FLM-1514B) to my Directv box and only get a blue screen on the tv.
Turn off blue screen in the menu of the TV if you can or cycle through the input sources on the remote to find the directv signal. Check cable setup in back of TV if it still does not work. Has the directv box been working with any other TV?
Apr 13, 2010 | Polaroid FLM-1514B LCD TV
I have a Polaroid FLM-323B LCD TV. Hooked up to an antenna, I cannot get to the HDTV tab in the menu section. When I hit the HDTV tab the screen goes blue and no remote button works until you hot the...
Hi
try resetting all menu option to factory default and see if anything change.
When resetting the menu, switch the TV off, pull the plug from the socket for about 30seconds and switch back on.
hope it helped
TekspotCoUk
Sep 07, 2009 | Computers & Internet
EEP RESET changed my picture to wide screen.
Go into Menu and look for Video section and find wide,panorama,16x9 and 4x3. gottas be there. then click on normal thnen click on what you want..
Please rate!!
Mar 16, 2009 | Polaroid TTM-2004 20" TV
Remote stuck on STB
Take the batteries out of your remote and let it sit for a few minutes. In plug your TV also. Wait a few minutes....Make sure the selector buttons are not stuck on the remote. plug things back together and see if it operates normally.
Feb 02, 2018 | Televison & Video
Stuck in zoom
Apr 23, 2008 | Polaroid FLM-323B Television
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Jan 16, 2008 | Directv RC23 Remote Control
Polaroid HD flat screen TV with DirecTV
I have Polaroid TV Monitor HDMI LCD 15.4" no power light on TV, blank screen, the power adaptor is Ok 12VDC supply. I need suggestion; in any possible problem or parts busted?
Sep 09, 2007 | Televison & Video
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
