Televison & Video Logo
Allen Klein Posted on Jan 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW DO I RESET LIGHT ON PANASONIC PT-521LCX65 TV HELD DOWN VOLUME-AND PIP AND MESSAGE STILL COMES ON WHEN I TURN TV ON. ALSO RED APPEARS IN BACKGROUND.
William Bailey
Level 2:
Sergeant:
  • Expert 171 Answers
  • Posted on Jan 11, 2019
William Bailey
Expert
Level 2:
Sergeant:
Answers
171
Questions
0
Helped
48709
Points
502
I hate to give you the bad news but that's a 2005 model and it wasn't exactly a high-end one. It would be cheaper to simply to go get a new one. Sorry
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Oct 31, 2008
SOURCE: panasonic Pt-53TW53G projection tv
5 Blinks means IC4511 thats located on the DG board which is the small board on the left side in front of the signal board looking in from the rear of the set.
Anonymous
  • Posted on Nov 04, 2008
SOURCE: OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Anonymous
  • Posted on Feb 19, 2009
SOURCE: Panasonic PT-50DL54J DLP TV Flashing Light
I had the same problems that most of you have been having, tv turning on and off, lights flashing in all different colors, having to unplug tv to reset and all of that good stuff. I noticed that most of the time this would happen once the tv would start to heat up, and I could hear the fan working a little harder. Well I am not an electrician but It was very simple to unscrew the lower bottom park of the tv, where the fan and most of the electronics sit, then I used an oxygen tank ( I work for a medical company ) to blow out all the dust in the tv, ( you can olso use the compressed air use for computer, but if grandma or grampa have some O2 laying around, it works really good, LOL. )and was very surpriced to see how dusty it was, then I removed the MAIN FAN ( you only need to remove three screws, however there's a box in fron of it, which you'll have to remove first in order to get to the fan ). this may sound a little complicated, but trust me it is not, once you have taken the fan off, clean it all the way around ( best to use a clean rag, the compressed air was not doing the job.
long story short, once I cleaned the fan and put it all back together. The TV still didn't work LOL, Just kidding, It has been working perfect for a little over a week.
If I can help in any other way, please e-mail me @ [email protected]
hope this helps.
Anonymous
  • 1239 Answers
  • Posted on May 03, 2009
SOURCE: red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
Anonymous
  • 1077 Answers
  • Posted on May 29, 2009
SOURCE: Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
I changed the lamp on my pt44-lcx65 panasonic tv and everything comes on great but red lamp light is still lit
Turn on the television.
  1. Press the volume down button on the TV display (not the remote!)
  2. While pressing the volume button, press the "split" or "PIP" button on your remote.
If it works, you'll see a message like this, an the lamp indicator light will turn off. Success!
Our panasonic HD tv displays every time we turn it on that the LAMP LIGHT needs to be replaced.....we replaced it.......it still pops up and last for about 2 minutes every time we turn on tv
Sir reset the lamp hour meter this will resolve the problem. Follow this instruction.
  • 1.Turn on your Panasonic television.
  • 2. Press and hold the - volume button on your television. Continue to hold the volume button and press and hold the "PIP" or "SPLIT" button on your remote control.
  • 3. Hold both button for five seconds and release. A message appears on your television screen indicating the meter has been reset.
  • 2helpful
    How reset the lamp in panasonic tv PT-50LC-14 ?
    While holding Volume Down button on TV Front and press and hold Play/ PIP button on tv Remote at same time for 6 or more seconds to reset lamp hours.
    TV will show lamp reset message on screen.
    Thanks.
    2helpful
    I have a large screen panasonic tv. The lamp
    Turn On tv.
    Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
    Hope this info will help you.
    Thanks.
    1helpful
    I just replaced the lamp on my Panasonic PT-40LC12 TV. How do I reset the timer and make the red light go off?
    what you need to do is have your remote handy and go up to the tv. Hold volume down the tv and pip on the remote for 5 seconds.
    3helpful
    2answers
    Resetting lamp hour meter on panasonic tv
    press volume down on tv and pip or split on remote
    14helpful
    2answers
    21helpful
    2answers
    How to reset the meter of lamp
    You need to have your Panasonic remote.
    1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
    2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
    PIP for Models:
    PT-50LC13/PT-60LC13/PT-50LCX63/
    PT-60LCX63/PT-43LCX64/
    PT-50LCX64/PT-60LCX64
    SPLIT for Models:
    PT-43LC14/PT-50LC14/PT-60LC14
    3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
    You will find a PDF of the instructions at this site:
    http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
    11helpful
    6answers
    Lamp meter on Panasonic PT-40LC12 ?
    I just had my picture go out two weeks ago. I took it to a local tv repair shop. They replaced the thermal fuse. I also had a spare lamp so they also replaced that. I'm not sure if they reset the lamp meter but this is what I found surfing around...try at your own risk. I'm going to try this when I go home tonight.
    Good Luck...
    Press the power button to turn the unit on.
    While pressing the Vol-(volume down) button on the projection display,
    hold down the PIP button on the remote control at the same time for more
    than 5 seconds. When the reset procedure is complete the following message
    will appear on the screen. "Lamp time was reset to 0".
    35helpful
    4answers
    Lamp reset
    This also works for the Panasonic PT-61LCX65. You hold the volume button down on the projection display, then hold down the Split/ DVD button on the remote control at the same time. I just did it after reading the advice posted. Thank you!
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
